Resistor box question...did a search
ok i have a resistor box at my house and it still has all the connectors attached to it....can i just put the 440s in the car and plug in the resistor box(obd1) and call it a night or do i still have to cut wires....
all info will help
all info will help
Cut wires.
https://honda-tech.com/zerothread?id=517274
I think there was someone that used hte plugs but IMO, just splice into the wires like my post.
I used the plugs, in case I wanted to go back and use Saturated [high impedance] injectors later on...therefore I wouldn't have to cut and solder again...only a plug and play matter.
Here are some pics [shown with the resistor box out of the loop]:
Sorry you can't see around the clutch MC very well. If you're interested, I could take some better pictures later.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaX »</TD></TR><TR><TD CLASS="quote">I used the plugs, in case I wanted to go back and use Saturated [high impedance] injectors later on...therefore I wouldn't have to cut and solder again...only a plug and play matter.
Does it work? If you follow how I did it it wouldn't work. I guess I am lost on what you did.
It isn't. You have to solder connectors into an OBD-1 harness to make it plug and play for the future. One way or another, if you're going to run a resistor box on an OBD-1 car, you are going to have to cut and solder some wires.
ok what i have is the whole injector harness with the resistor box. clips and all...all the wiring even the four or 5 wires that go to the ecu from the injectors...can i just swap all that stuff out for the old....
I was the one with the write up.
Follow these instructions and you dont have to cut any of your OEM wires.
https://honda-tech.com/zerothread?id=736737
