which cam is better????
Old Jul 12, 2004 | 03:37 AM
96civich22's Avatar
Default which cam is better????
i'm looking for a better cam the the stock jdm itr cams. not running nos or turbo going all motor and need some advice
Old Jul 12, 2004 | 04:28 AM
Xsi's Avatar
Xsi
All type R cams are so close in spec you will hardly notice. If you want better go for Skunk2 stage 1's or bigger
Old Jul 12, 2004 | 06:36 AM
Toda Built's Avatar
Default Re: (Xsi)
go with toda's or jun's
Old Jul 12, 2004 | 06:46 AM
elementmilwaukee
Guest
Posts: n/a
Default Re: (Toda Built)
Web cams.. However, I've had a lot of experianced engine builders tell me that with my turbo B18C to stick with GSR cams, they will perform better..
Old Jul 12, 2004 | 07:14 AM
shamoo's Avatar
Will you make something up for me please?
Default Re: (elementmilwaukee)
A pretty vague question here.
So you're asking what's a better cam. A stock set or an aftermarket set. Which aftermarket set?
Old Jul 12, 2004 | 07:59 AM
crawdad689's Avatar
Default Re: (shamoo)
as said before, JDM itr cams and the b16b cams are pretty much the same thing.
It all depends on your goals... if you wanna see some REAL hp gains, well then go w/ say toda b-spec or skunk2 stageII's or something like that, but if you wanna go FI eventually or something like that, then i'd just get some ctr's and call it a day
LS/V-T
Dec 28, 2010 10:15 AM
H8BOOST
Oct 10, 2010 02:30 PM
12345
Feb 16, 2003 08:28 AM
b18cInside
Dec 19, 2002 05:41 AM
98gsr
Sep 15, 2001 07:35 PM
