(Searched) OBD2 motor using OBD1 ECU?
As topic title states...I wanted to use my p28 w/hondata setup on my OBD2 motor...I know I am going to need a conversion harness. Here are a few questions I have.
1) Am I going to need to change injector style...OBD2 integras are saturated correct?
Are OBD1 integra's saturated also?
2) Am I going to have to change distributor style or anything of that nature?
Reason I ask is because on my old engine (h22), if I wanted to go from OBD1->OBD2...I would have needed to convert my peak and hold injector setup to the saturated style...and the distributor to a external coil setup. Help me out H-T! Thanks!
Modified by teameracer3 at 10:09 PM 7/11/2004
1. No
2. No
All you need is the conversion harness, however note that if you are using the stock intake manifold with the secondary butterflies, the P28 will not be able to control them.
2. No
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall »</TD></TR><TR><TD CLASS="quote">1. No
2. No
All you need is the conversion harness, however note that if you are using the stock intake manifold with the secondary butterflies, the P28 will not be able to control them.</TD></TR></TABLE>
ohh alrite sick..thanks...now just for my own knowledge...integras do use saturated style injectors correct?
2. No
Adam West
May 8, 2006 03:47 AM
