EGT and Oil pressure refrences....(D series)
Old Jul 11, 2004 | 01:50 PM
ATS*Mark's Avatar
OG triple OG
Default EGT and Oil pressure refrences....(D series)
hey guys , i know there have peen posts seeing if their egts or oil pressures are right . but i havent seen any D series numbers .
im wondering what you D series guys are seeing on your guages .
my oil pressure is like 75 on a cold startup , like 23psi at idle when warm . 47 when cruising at 80 on the freeway .
my egt's are 4-600 at idle and about 1200 cruising at 80 on the freeway.
havent done anthing WOT as im breaking in the motor so i dont know those numbers.
Old Jul 11, 2004 | 02:26 PM
Blackack26's Avatar
Default Re: EGT and Oil pressure refrences....(D series) (Hella_JDM)
Where is the EGT probe tapped?
The readings will differ say from the mani compared to the dp.
Old Jul 11, 2004 | 02:36 PM
ATS*Mark's Avatar
OG triple OG
Default Re: EGT and Oil pressure refrences....(D series) (Blackack26)
its tapped in the downpipe right after the turbo
Old Jul 11, 2004 | 02:51 PM
JDMCRX's Avatar
That sounds about right u loose 200 deg after the turbo. Im at 800 on idle
Old Jul 11, 2004 | 02:53 PM
ATS*Mark's Avatar
OG triple OG
Default Re: EGT and Oil pressure refrences....(D series) (JDMCRX)
what are you at full boost at wot?
Old Jul 11, 2004 | 02:59 PM
JDMCRX's Avatar
Was over 1600 lol now tunned around 1400
Old Jul 11, 2004 | 04:59 PM
ATS*Mark's Avatar
OG triple OG
cool , cause i can almost tell its going to want to peg when i give it wot
Old Jul 11, 2004 | 05:05 PM
J337_UNIT's Avatar
80psi at start up
20-25 when warm at idle and 75 at WOT
EGT temps are:
600-800 at idle
1400 degrees fahrenheit -1450(the most) cruising around 70-80.
DIDNT REALIZE THIS THREAD WAS FOR D SERIES.. mine is B series yours may be different...
Modified by J337_UNIT at 12:08 AM 7/12/2004
Old Jul 11, 2004 | 07:42 PM
USDM 4G VTEC's Avatar
i get 80 psi idle cold oil
10 psi on idle when hot
when really hot, drops to like 8-9 psi
egt not yet since i havent got it
Old Jul 11, 2004 | 08:08 PM
jazz215's Avatar
Default Re: (USDM 4G VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by USDM 4G VTEC &raquo;</TD></TR><TR><TD CLASS="quote">i get 80 psi idle cold oil
egt not yet since i havent got it </TD></TR></TABLE>
exactly same for me.. is it normal to get so low? although the oil pressure always stays about 10psi higher than every 1k rpm. so driving at 3k rpm would put me at 40psi
Old Jul 11, 2004 | 08:15 PM
djfob's Avatar
oil cold start-80 psi
cruise-40-45psi
warm idle-15psi
egt at idle is about 700 and no more than 1200 on the highway.
Old Jul 11, 2004 | 08:27 PM
Quad-Damag's Avatar
Default Re: (djfob)
cold start like 30 to 40 for me
warmed up idel 20 to 27
wot like 68 70ish
Old Oct 23, 2004 | 02:07 PM
Snail Tuning's Avatar
Default Re: (Quad-Damge)
im at 12-15lbs at idle.
EGT im seeing up to 1536 at WOT in 4th gear on hard pulls. #3 cyl runner
i have the ziertronix wideband o2 sensor so i can datalog
ill post a graph up. i may still have my timing retarded to much.
bump cause im bringing this thread back to life
Old Oct 23, 2004 | 06:50 PM
2muchPSI's Avatar
Default Re: (Snail Tuning)
oil pressure
80 startup
45 cruising
10-15 hot idle
EGT's
about 800 idle, 1200 cruising at 80 mph
Old Oct 23, 2004 | 07:00 PM
Blazin Civic's Avatar
Default Re: (2muchPSI)
My oil pressure is like 100psi at idle then drops all the way down to 10 or so once it is warmed up at idle. Rest is rpm dependent. My EGT still isn't hooked up yet so not sure of it. LoL one of my friends was like holy **** pull over your EGTs are off the charts! LoL he didn't realize it wasn't plugged in.
soontobeboost
Jan 6, 2007 06:22 AM
AsSanitySlipsAway
12
Aug 18, 2006 06:29 PM
zexifiedlude
Jul 2, 2006 07:18 AM
1.8
Mar 26, 2005 12:17 PM
IntegD
Jan 8, 2003 09:31 PM
