EGT and Oil pressure refrences....(D series)
OG triple OG
hey guys , i know there have peen posts seeing if their egts or oil pressures are right . but i havent seen any D series numbers .
im wondering what you D series guys are seeing on your guages .
my oil pressure is like 75 on a cold startup , like 23psi at idle when warm . 47 when cruising at 80 on the freeway .
my egt's are 4-600 at idle and about 1200 cruising at 80 on the freeway.
havent done anthing WOT as im breaking in the motor so i dont know those numbers.
Re: EGT and Oil pressure refrences....(D series) (Hella_JDM)
Where is the EGT probe tapped?
The readings will differ say from the mani compared to the dp.
80psi at start up
20-25 when warm at idle and 75 at WOT
EGT temps are:
600-800 at idle
1400 degrees fahrenheit -1450(the most) cruising around 70-80.
DIDNT REALIZE THIS THREAD WAS FOR D SERIES.. mine is B series yours may be different...
Modified by J337_UNIT at 12:08 AM 7/12/2004
EGT temps are:
600-800 at idle
Re: (USDM 4G VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by USDM 4G VTEC »</TD></TR><TR><TD CLASS="quote">i get 80 psi idle cold oil
10 psi on idle when hot
when really hot, drops to like 8-9 psi
egt not yet since i havent got it </TD></TR></TABLE>
exactly same for me.. is it normal to get so low? although the oil pressure always stays about 10psi higher than every 1k rpm. so driving at 3k rpm would put me at 40psi
Re: (Quad-Damge)
im at 12-15lbs at idle.
EGT im seeing up to 1536 at WOT in 4th gear on hard pulls. #3 cyl runner
i have the ziertronix wideband o2 sensor so i can datalog
ill post a graph up. i may still have my timing retarded to much.
bump cause im bringing this thread back to life
Re: (2muchPSI)
My oil pressure is like 100psi at idle then drops all the way down to 10 or so once it is warmed up at idle. Rest is rpm dependent. My EGT still isn't hooked up yet so not sure of it. LoL one of my friends was like holy **** pull over your EGTs are off the charts! LoL he didn't realize it wasn't plugged in.
AsSanitySlipsAway
12
08-18-2006 06:29 PM
