Senor Questions
Old Jul 11, 2004 | 01:47 PM
Synth124's Avatar
Default Sensor Questions
Car: 1991 Crx dx dpfi d15
1) IF the ECU does not detect any signal from the oil pressure sensor will that prevent the engine from running? Will it basically tell the ecu not to let the engine to run?
2) If the main fuel injector (91crx dpfi) is out of spec: 2.2/2.3 ohms insted of .6-1/6ohms will the ecu prevent the engine from running? I know buick has that feature.
thanks and peace
synth
Old Jul 11, 2004 | 01:50 PM
KaoticSnow's Avatar
Default Re: Senor Questions (Synth124)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Synth124 &raquo;</TD></TR><TR><TD CLASS="quote">1) IF the ECU does not detect any signal from the oil pressure senor will that prevent the engine from running? Will it basically tell the ecu not to let the engine to run?</TD></TR></TABLE>Doubt it considering its not going to get any oil pressure till the engien is running.
Synth124's Avatar
Default Re: Senor Questions (KaoticSnow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KaoticSnow &raquo;</TD></TR><TR><TD CLASS="quote">Doubt it considering its not going to get any oil pressure till the engien is running.</TD></TR></TABLE> Well she cranks, she just doesn't run, and I do get oil pressure. I'm running a aftermarket oil psi gauge
Old Jul 11, 2004 | 01:52 PM
Synth124's Avatar
Yes I do know that I did not spell sensor correct on the thread title
EGKREW
45
Sep 11, 2007 08:01 PM
agiorlando
May 18, 2007 11:31 AM
SPRLude
Apr 27, 2006 08:09 PM
CRX-ZC
Sep 2, 2005 02:19 PM
chinners10
Oct 1, 2003 12:46 PM
