Possible electrical problem, PLEASE help???
Old Jul 11, 2004 | 10:14 AM
Milano97's Avatar
Default Possible electrical problem, PLEASE help???
Hi,
My car has been recently having a little bug...I am driving normally, usually highway speeds about 40-60mph but then when I ONLY hit the brakes to slow down, like at a stoplight/sign, or slower moving traffic, my radio sometimes shuts off for a second then goes back on. Also, the tachometer and speedometer also flick on and off for a second. It doesn't happen EVERY time I hit the brakes, but it usually happens when I am slowing down from highway speeds.....For example, I am cruising at 55mph, and I hit the brakes lightly to slow down. The radio would turn off for a second or two, and the tachometer and speedometer needles would both drop down to 0 really fast like the car died then a second later they go back up to the rpm's/speed the car was orginally moving at. Also, the tach/speedometer doesn't always just shut down, most of the time it's just the radio. The tach/speedometer needles will flick off then back on only occassionally. Is this an electrical problem? The car NEVER turns off or shuts itself off, it is always running. It only happens when I step on the brakes sometimes, not when I'm cruising around at a steady speed. Any info you guys can give? Thanks for any replies.
Modified by Milano97 at 8:47 PM 7/11/2004
Old Jul 11, 2004 | 11:45 AM
Milano97's Avatar
Default Re: Possible electrical problem, PLEASE help??? (Milano97)
Anyone? Please? I did a search and couldn't find anything useful...
Old Jul 11, 2004 | 04:10 PM
Milano97's Avatar
Bump
Old Jul 11, 2004 | 04:39 PM
2lua's Avatar
you got a short, or grounds lose. i would check around your brake pedal or your radio first.
Old Jul 11, 2004 | 05:28 PM
Milano97's Avatar
Thanks...I had a feeling something like that was probable, but I wasn't exactly sure...anyone else have a suggestion?
cholder919
Sep 19, 2011 09:14 AM
SFlCrx
Mar 5, 2006 06:56 PM
d_mina
Dec 7, 2003 04:16 PM
RS1995
Jun 8, 2002 08:17 PM
deviant94ex
Mar 7, 2002 05:47 AM
