HELP!!!!
all you gotta do is this...
remove all air... pop the bead wire off the rims on both sides so its just sitting in the "well"
use a screwdriver or just something to put between the wheel and tire, and lift the wall of the tire above the rim... now pull up on it as much as possible and make sure to try and keep the wheel pushed down as much as possible throughout the entire process. take another screwdrive and run it along the edge of the rim poppin up the tire until the entire top bead wire is above the rim...
now run the screwdriver down (must be a long one) and sit it on the inside lip of the rim with the bead wire on the other side. as the screwdriver is sittin there.... hold the tire on the bottom and lift up on the opposite side where the screwdriver is sitting and then immediately pull up on the side with the screwdriver... now make the screwdriver lay down with the end between the bead wire and the rim and the other end just exposed. take the other screwdriver and put it between the bead wire andrim and run it along popping the tire up and off the rim. go all around and bam, ur good to go, tire is off
much easier with a machine
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by riceburner247 »</TD></TR><TR><TD CLASS="quote">
Just take it to a tire shop before you hurt yourself. seriously.......</TD></TR></TABLE>
hahahahahahhahahaahah!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by riceburner247 »</TD></TR><TR><TD CLASS="quote">Just take it to a tire shop before you hurt yourself. seriously.......</TD></TR></TABLE>
Hey if you have not noticed it is sunday and most places are not open on sunday.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schmitey »</TD></TR><TR><TD CLASS="quote">have fun putting them back on though!!!</TD></TR></TABLE>
my thoughts exactly
my thoughts exactly
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by david90 »</TD></TR><TR><TD CLASS="quote">***.</TD></TR></TABLE>
I found a thread for ya buddy.
https://honda-tech.com/zerothread?id=739237
https://honda-tech.com/zerothread?id=739237</TD></TR></TABLE>
haha PHDTS
haha PHDTS
