HELP!!!!
Old Jul 10, 2004 | 07:34 PM
jakeiscool's Avatar
Banned
Default HELP!!!!
How should i remove tires from some accord wheels i have?? thanks we are trying to do this tonight
Old Jul 10, 2004 | 07:38 PM
madd's Avatar
Default Re: HELP!!!! (JakeIsCool)
let the air out and use a long flat head screw driver, a 5 gallon bucket, and rubber mallet? maybe it'll work?
Old Jul 10, 2004 | 07:52 PM
FatJoe's Avatar
Default Re: HELP!!!! (madd)
all you gotta do is this...
remove all air... pop the bead wire off the rims on both sides so its just sitting in the "well"
use a screwdriver or just something to put between the wheel and tire, and lift the wall of the tire above the rim... now pull up on it as much as possible and make sure to try and keep the wheel pushed down as much as possible throughout the entire process. take another screwdrive and run it along the edge of the rim poppin up the tire until the entire top bead wire is above the rim...
now run the screwdriver down (must be a long one) and sit it on the inside lip of the rim with the bead wire on the other side. as the screwdriver is sittin there.... hold the tire on the bottom and lift up on the opposite side where the screwdriver is sitting and then immediately pull up on the side with the screwdriver... now make the screwdriver lay down with the end between the bead wire and the rim and the other end just exposed. take the other screwdriver and put it between the bead wire andrim and run it along popping the tire up and off the rim. go all around and bam, ur good to go, tire is off much easier with a machine
Old Jul 10, 2004 | 07:59 PM
jakeiscool's Avatar
Banned
Default Re: HELP!!!! (FatJoe)
Alright thanks guys
Old Jul 10, 2004 | 08:02 PM
FatJoe's Avatar
hope my explaination isnt too...foreign language
Old Jul 10, 2004 | 09:06 PM
Schmitey's Avatar
picture a big *** bike tire minus the tube...same idea
have fun putting them back on though!!!
Old Jul 10, 2004 | 09:36 PM
Riceburner247's Avatar
Default Re: HELP!!!! (Schmitey)
Just take it to a tire shop before you hurt yourself. seriously.......
Old Jul 10, 2004 | 10:53 PM
FatJoe's Avatar
Default Re: HELP!!!! (riceburner247)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by riceburner247 &raquo;</TD></TR><TR><TD CLASS="quote">
Just take it to a tire shop before you hurt yourself. seriously.......</TD></TR></TABLE>
hahahahahahhahahaahah!
Old Jul 11, 2004 | 08:32 AM
david90's Avatar
why are u posting a picture of my neighbor? ***.
Old Jul 11, 2004 | 08:34 AM
-RedneckDave-'s Avatar
Working
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by riceburner247 &raquo;</TD></TR><TR><TD CLASS="quote">Just take it to a tire shop before you hurt yourself. seriously.......</TD></TR></TABLE>
Hey if you have not noticed it is sunday and most places are not open on sunday.
Old Jul 11, 2004 | 09:58 AM
jwogen1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schmitey &raquo;</TD></TR><TR><TD CLASS="quote">have fun putting them back on though!!!</TD></TR></TABLE>
my thoughts exactly
Old Jul 11, 2004 | 10:03 AM
FatJoe's Avatar
Default Re: HELP!!!! (jwogen1)
its actually easier to put em on than it is to take em off.... at least to me it is.
Old Jul 11, 2004 | 11:39 AM
Default Re: (david90)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by david90 &raquo;</TD></TR><TR><TD CLASS="quote">***.</TD></TR></TABLE>
I found a thread for ya buddy.
https://honda-tech.com/zerothread?id=739237
Old Jul 22, 2004 | 12:08 PM
jakeiscool's Avatar
Banned
Default Re: (riceburner247)
https://honda-tech.com/zerothread?id=739237</TD></TR></TABLE>
haha PHDTS
Wannabe JDM
Nov 19, 2007 09:22 AM
vdub08
Jan 18, 2005 06:52 AM
binxers
Oct 13, 2004 03:02 PM
2k1_ITR_0736
Jun 23, 2003 08:27 PM
Mr.Rab
Jul 1, 2002 09:05 PM
