Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Could this be used as a cheap yet effective oil cooler setup? (Ford tranny cooler)
Old Jul 7, 2004 | 02:33 PM
ActiveAero's Avatar
Paragraph Alert
25 Year Member
Community Builder
Community Influencer
Default Could this be used as a cheap yet effective oil cooler setup? (Ford tranny cooler)
http://store.summitracing.com/...N=120 306544
It's a Ford racing heavy duty transmission oil cooler (full specs can be found in the link). I'm sure it's not the end all of oil coolers, but for a weekend warrior do you think it would be a nice addition to keep oil temps in check?
It says it features its own thermostat like bypass feature which could be good or bad. I don't know what the normal operating temp of the tranny should be, but if its around 180 degrees then I don't see a problem with it.
I figure I could buy this kit, spend some extra $ for some quality lines, and come out with a decent and very reasonably priced oil cooler setup.
Any opinions or input is more than welcome.
Old Jul 7, 2004 | 02:35 PM
MattD@Stoptech's Avatar
Default Re: Could this be used as a cheap yet effective oil cooler setup? (ActiveAero)
yeah...don't bother...you're not going to circulate enough oil through that to be of much benefit...and i would even venture a guess that you'd loose a lot of pressure.
Old Jul 7, 2004 | 02:53 PM
Grumpy's Avatar
New User
Default Re: Could this be used as a cheap yet effective oil cooler setup? (El Pollo Diablo)
I agree. Not designed to do the job. I tryed something similar once, then had to by a realil cooler.
Old Jul 7, 2004 | 03:01 PM
ActiveAero's Avatar
Paragraph Alert
25 Year Member
Community Builder
Default Re: Could this be used as a cheap yet effective oil cooler setup? (Grumpy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Grumpy &raquo;</TD></TR><TR><TD CLASS="quote">I agree. Not designed to do the job. I tryed something similar once, then had to by a realil cooler.</TD></TR></TABLE>
Thanks for the input guys. Oh well it was worth a shot.
RedneckRicer
May 16, 2008 10:48 AM
SoulSurfer
Nov 8, 2002 06:22 AM
tFUnK
Apr 6, 2002 05:22 PM
4dGSR at work
Oct 31, 2001 01:39 PM
