Possible shipping damage
Old Jul 7, 2004 | 02:13 PM
eda6's Avatar
Default Possible shipping damage
here's a pic from an itr intake manifold. The line looks kinked to me.
Does this look right or is it damaged?
this is the where the vacuum hose from brake booster connects to
intake manifold.
I wanna know so i can contact seller/shipper if there's a problem.
TIA
Old Jul 7, 2004 | 02:14 PM
Jonathan_ED3's Avatar
It's definitely damaged, but I don't think it's non useable.
Old Jul 7, 2004 | 02:20 PM
Nocturnal_Lude's Avatar
Default Re: (Jonathan_EH)
yea, its bent, but like it was said, unless theres a crack or some break in it, it still very usable. Worst case scenerio is a little resistence in air flow, but nothing you'd notice i think...
Old Jul 7, 2004 | 02:23 PM
Keebler's Avatar
Default Re: Possible shipping damage (eda6 hb)
Its fuxxored... Get a new end piece, your vaccum will not be sufficient for the brake booster, you WILL notice it.
Old Jul 7, 2004 | 02:24 PM
APEX CRX's Avatar
Default Re: Possible shipping damage (Keebler)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Keebler &raquo;</TD></TR><TR><TD CLASS="quote">Its fuxxored... Get a new end piece, your vaccum will not be sufficient for the brake booster, you WILL notice it.</TD></TR></TABLE>
I agree. a kink like that will limit the vacuum
Old Jul 7, 2004 | 02:27 PM
4drEF's Avatar
Keyboard Humorist
Baaah... bend it back and squeeze it round again with pliers.
I'm sure it would work fine.
Old Jul 7, 2004 | 02:29 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
My friends was like that..
I stuck a straight punch inside the tube and squeezed the kinked
portion of the tube with some pliers while pulling outward on the punch
in order to straighten it..
Old Jul 7, 2004 | 02:30 PM
kid-honda's Avatar
pull one off your old motor, this happens all the time, they just twist out.
Old Jul 7, 2004 | 02:38 PM
RCautoworks's Avatar
Default Re: (kid-honda)
Yep just twist it off and pop the new one in.
Old Jul 7, 2004 | 02:45 PM
MENACE's Avatar
Default Re: (90blackcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kid-honda &raquo;</TD></TR><TR><TD CLASS="quote">pull one off your old motor, this happens all the time, they just twist out.</TD></TR></TABLE>
Yep I agree. Just pull it out and put a new on in. If you have a hard time getting it to stay in use some Locktite Red. Thats what i did it worked great.
Old Jul 7, 2004 | 02:59 PM
eda6's Avatar
Default Re: (MENACE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MENACE &raquo;</TD></TR><TR><TD CLASS="quote">
Yep I agree. Just pull it out and put a new on in. If you have a hard time getting it to stay in use some Locktite Red. Thats what i did it worked great.</TD></TR></TABLE>
i got loctite 242. this isn't worth contacting shipper/seller.
It should come out easily with a couple crescent wrenches.
Should be an easy fix.
Old Jul 7, 2004 | 03:39 PM
senpai's Avatar
Yea, I bought a head with bent exhaust manifold studs, but I wasn't going to make a fuss about it.
Old Jul 7, 2004 | 04:11 PM
LAMA's Avatar
Old Jul 7, 2004 | 05:58 PM
how much do those pieces cost brand new?
Old Jul 7, 2004 | 06:03 PM
KaoticSnow's Avatar
agreed, it will still work but when it comes to the breaks don't chance it.
Old Jul 7, 2004 | 08:30 PM
eda6's Avatar
Removed bent piece. It was more work than I expected.
Now to find replacement piece. Any suggestions.
I don't think I can get one from another car without damaging it
in the process.
Old Jul 7, 2004 | 08:55 PM
Origin's Avatar
i suppose this was used? if it was new, then get the seller to send you a new one. if not im sure you can get this at honda/acura parts dealer.
Old Jul 7, 2004 | 10:30 PM
Keebler's Avatar
Id try the junkyard for a replacement.
Use a heat gun next time to warm the manifold, it will pop right out, and right in...should limit the scarring and damage
masterasia
Sep 21, 2005 01:02 AM
Terrabomb
Jul 23, 2005 01:53 PM
Declectic
20
Nov 11, 2004 12:03 PM
JDubya
Dec 30, 2003 02:13 PM
redhatchb18
Oct 23, 2003 10:27 AM
