block swap complete.....now no start
Old Jul 6, 2004 | 10:31 AM
temp's Avatar
Default block swap complete.....now no start
i am stumped.......it cranks over good n hard but it wont start, everything is hooked up........suggestions?
Old Jul 6, 2004 | 10:34 AM
kKdARIAN's Avatar
Vice President/CEO
Default Re: block swap complete.....now no start (temp)
you've done all the normal stuff, checked spark, fuel etc...
have you checked the valve lashings?
Old Jul 6, 2004 | 10:41 AM
89dxhunchback's Avatar
Default Re: block swap complete.....now no start (kKdARIAN)
check grounds too.
Old Jul 6, 2004 | 10:51 AM
temp's Avatar
problem is its just me by myself so i cant check spark or fuel, the fuel pump is coming on that i know for sure, but as for if its delivering fuel i dont know and same for spark
Old Jul 6, 2004 | 10:53 AM
APEX CRX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by temp &raquo;</TD></TR><TR><TD CLASS="quote">problem is its just me by myself so i cant check spark or fuel, the fuel pump is coming on that i know for sure, but as for if its delivering fuel i dont know and same for spark</TD></TR></TABLE>
time to get a buddy over there for help. for spark pull a plug wire and spark plug out and have a buddy crank while you hold it to a ground. Should arc. As for fuel loosen up the 17mm bolt on the fuel line and have a friend turn the key to start postion to see if fuel comes out.
Old Jul 6, 2004 | 10:55 AM
temp's Avatar
Default Re: block swap complete.....now no start (APEX CRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by APEX CRX &raquo;</TD></TR><TR><TD CLASS="quote">
time to get a buddy over there for help. for spark pull a plug wire and spark plug out and have a buddy crank while you hold it to a ground. Should arc. As for fuel loosen up the 17mm bolt on the fuel line and have a friend turn the key to start postion to see if fuel comes out.</TD></TR></TABLE>
lol yeah thats the problem, all t3h buddies are at work right now....all the grounds are hooked up (thermostat housing, front of engine, tranny)......anything else you guys could suggest that i could check myself?
Old Jul 6, 2004 | 11:03 AM
temp's Avatar
ok i just checked for spark, what i did was i pulled the number 4 plug and put it in the plug wire, set it on the VC and cranked it.......there was spark
i do smell gas....perhaps there is a leak?
Old Jul 6, 2004 | 11:59 AM
I3ackfire's Avatar
Is your timing correct?
Old Jul 6, 2004 | 12:05 PM
temp's Avatar
Default Re: block swap complete.....now no start (I3ackfire)
yes the timing was set correctly
Old Jul 6, 2004 | 12:38 PM
temp's Avatar
ok so i just went and loosened teh 12mm bolt on the fuel filter and fuel came out (i didnt crank it).....so i am stumped? if the block had low compression would it still start?
Old Jul 6, 2004 | 01:12 PM
4drEF's Avatar
Keyboard Humorist
Deends how low you are talking about. You need compression or the fuel won't explode when it's ignited.
Old Jul 6, 2004 | 02:01 PM
temp's Avatar
Default Re: block swap complete.....now no start (4drEF)
ok and how about the clutch.....i am pretty sure it was installed properly but still.......if the clutch/flywheel werent done right that could cause an issue too right?
Old Jul 6, 2004 | 02:14 PM
temp's Avatar
ok.....perhaps i was wrong, i dont think i am getting any spark, should it arc between the plug element and the little "L" at the end of the plug?
Old Jul 6, 2004 | 02:57 PM
mr. carpenter's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by temp &raquo;</TD></TR><TR><TD CLASS="quote">ok so i just went and loosened teh 12mm bolt on the fuel filter and fuel came out (i didnt crank it).....so i am stumped? if the block had low compression would it still start?</TD></TR></TABLE>
did it just come out or did it spray out?
Old Jul 6, 2004 | 03:03 PM
I3ackfire's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by temp &raquo;</TD></TR><TR><TD CLASS="quote">ok.....perhaps i was wrong, i dont think i am getting any spark, should it arc between the plug element and the little "L" at the end of the plug?</TD></TR></TABLE>
Just set it on the rad support and see if a spark happens. Try one at a time.
Old Jul 6, 2004 | 08:07 PM
temp's Avatar
well it started, it was t3h distributor it wasnt flushed all the way (IIIIIDDDDIIIIOOOOTTTT) anyways.......now i have a new problem, the oil light is staying on even though the oil is full (it turns off sometimes when you rev it, it will turn off for a bit then it will come back on).......which leads me to believe 1 of the following, bad oil pump or bad sensor.....anything else it could be?
Draiga1988
Oct 24, 2010 07:20 PM
trav143
11
Oct 8, 2008 10:58 AM
pbizzlegsr
Aug 27, 2004 08:55 AM
2ndGenREX
Dec 3, 2003 07:11 PM
[626]95-GSR
30
Feb 16, 2002 12:06 PM
