Manual Trans
Old Jul 6, 2004 | 09:51 AM
rdaggett's Avatar
Default Manual Trans
I have a 94 CX HB and I am having problems with it making a clicking noise when I accel and a slight chatter when sitting in idle ..... When I push in the clutch the chatter goes away .....
also i turn sharp left or right and there is no clicking .... what I think the problem is ..... I think it is the throw out bearing .....
what do you all think?
also if I need to replace the axles it states in the Haynes manual the trans takes 2 qt. of 5w-30 .... has anyone ever used synthetic in a manual trans?
Old Jul 6, 2004 | 10:11 AM
kKdARIAN's Avatar
Vice President/CEO
Default Re: Manual Trans (rdaggett)
Search...
https://honda-tech.com/zerothread?id=893932
Problem: Bad input shaft bearing
Symptoms: https://honda-tech.com/zerothread?id=590820
Replacement: https://honda-tech.com/zerothread?id=596873
Actually it could be any of the bearings on the mainshaft. The input shaft bearing is the one that fails the most. You'll have to disassemble your transmission, and spin all of the bearings on the mainshaft (including the input shaft bearing) and listen for clicking...and replace the ones that click.
Old Jul 6, 2004 | 10:12 AM
rdaggett's Avatar
Default Re: Manual Trans (kKdARIAN)
thanks man!
Deemeetree's Avatar
Electrician
Damn...beat me to it!
Do this while you're at it:
https://honda-tech.com/zerothread?id=912219
CptHMCrunch
Jul 16, 2015 05:10 PM
return_2020
Honda Civic (2001 - 2005)
17
May 31, 2008 11:32 PM
blouisgod
Jan 11, 2007 04:18 PM
exx
10
May 10, 2004 08:03 AM
exx
May 4, 2004 10:10 AM
