Rear drum and rear disks lower arm interchangable?
Does anyone know if the rear drum brakes trailing arm is interchangable with the rear disk brakes trailing arm. Like can I bring the calipers and rotors and use it on the drum brakes rear trailing arm.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wdskuk »</TD></TR><TR><TD CLASS="quote">Really sweet. So y does everyone change the whole arm out</TD></TR></TABLE>
It's easier than dealing with the torx bolts, and a lot of people used to say you needed the whole arm, but I have swap just the spindles and it's fine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92b16vx »</TD></TR><TR><TD CLASS="quote">
It's easier than dealing with the torx bolts</TD></TR></TABLE>
Werd! Those 3 bolts will strip faster than Nicole Ritchie
Yes they are. In fact I am in the process of doing that now. I am having some major problems though with corrosion and rusting. THe LCA bolts are sheared off, the torx bolts are rusted in and the fact that I don't have a lift is a pain in the ***. Strongly recommend a lift where leverage is better! Cheers!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vizeta »</TD></TR><TR><TD CLASS="quote">hi CBracing, can u use the drum hubs for disks? thanks.</TD></TR></TABLE>
No, they are "one piece", you can take them all apart, but drums are drums, and disc are disc.
Mar 8, 2004 11:14 AM
DOHC-DX
11
Sep 18, 2002 06:47 AM
