mugen power cut off switch?????
Old Jul 4, 2004 | 11:26 PM
cuz_ican's Avatar
Default mugen power cut off switch?????
does anyone have this? know what it does? or how it works? i allready searched.
Modified by cuz_ican at 8:38 AM 7/5/2004
Old Jul 4, 2004 | 11:30 PM
dogfood's Avatar
Default Re: mugen power cut off switch????? (cuz_ican)
your picture ain't showin up bro
Old Jul 5, 2004 | 12:27 AM
cuz_ican's Avatar
Default Re: mugen power cut off switch????? (dogfood)
does anyone have any info on this?????
Old Jul 5, 2004 | 12:29 AM
hasback*'s Avatar
F*CK THIEVES!
yo yo
https://honda-tech.com/zerothread?id=892415
Modified by hasback_00 at 6:00 AM 7/5/2004
Old Jul 5, 2004 | 12:44 PM
cuz_ican's Avatar
Default Re: mugen power cut off switch????? (hasback_00)
thanks for the info! but if you use it as a battery cut off would you still be able to use your alarm?
Old Jul 5, 2004 | 01:09 PM
zanthrax's Avatar
That wouldn't be very effective since the 'lock' can be turned with any flat piece of metal.
I put quotes around the word lock because these things are more like an on/off switch with a detachable **** meant to be used as emercency power cut-off switches.
Old Jul 5, 2004 | 02:08 PM
menkio's Avatar
Default Re: (zanthrax)
dood.. it mugen. thieves would see it and say.. ohh snap the moogen in da house, we bounce.
Old Jul 5, 2004 | 02:13 PM
SkyeC's Avatar
Boba Connoisseur
25 Year Member
that's more of a racecar thing that you have on the outer body of the car... not something most people use for a alarm-type killswitch...
Old Jul 21, 2004 | 05:29 AM
nickgomez's Avatar
Default Re: mugen power cut off switch????? (SkyeC)
Thats part of a lot of stuff Mugen has for DC5s in the Honda Onemake Race Association events. Check out http://www.hoa.jp I think the regulations state you have to have a battery cutoff switch which can be operated from inside AND outside the car.
There's also front/rear towhooks, bonnet pins, tailgate fastener, drivers footrest, foot panel, Accel pedal stopper, side lining, fire extinguisher, seat rails, roll cage, window net, ECU, ECU mount bracket, fuel pressure regulator, oil catch tank, transmission cooler, clutch, oil pan, aluminum radiator, engine oil, etc. LOTS of Mugen stuff you don't see over there in the US.
Why would you want track stuff on a street car?
If you're interested in car security check out Thatcham Category 1 at http://www.thatcham.org
Modified by nickgomez at 10:45 PM 7/21/2004
Old Jul 21, 2004 | 05:39 AM
Deemeetree's Avatar
Electrician
If you want Security, rig up a kill switch for your fuel pump and ignition. $10 later, it's hard to start your car without knowing where the switches were.
SpoolinEK9
Audio / Security / Video
Jun 21, 2004 07:44 PM
Si Erik
Dec 25, 2003 07:49 PM
non-VTEC
Jul 1, 2002 08:06 PM
