Help: Fuel pump not priming, car not staying on But it cranks
The motor cranks over and it'll start for a second then die.
When i put the key to the on position, none of the dash lights come on and the fuel pump doesn't primer. if i hold the key to the start position the car will stay running but then it'll die a second later.
Let me know what you think it is.
nah ivan it was but now it isn't so i think everything is grounded...
i bought a new mainrelay to try out though....
hold the key to the cranking position....
Well hopefully the main relay will cure this problem...
Thanks
Any other ideas?
Thanks
Any other ideas?
sounds like bad ignition wiring or switch if you are getting the car to RUN (not just crank) with the key in "start", but not in "on".
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4drEF »</TD></TR><TR><TD CLASS="quote">sounds like bad ignition wiring or switch if you are getting the car to RUN (not just crank) with the key in "start", but not in "on".</TD></TR></TABLE>
THis is KoRE
That's what i htought so i ordered the harness it'll be here tommorow how do you install a new switch?
THis is KoRE
LilMissCrystal81
Nov 19, 2004 11:26 AM
