Clutch Problem Need Help!!!
Old Jul 3, 2004 | 02:15 PM
xpurespeedx's Avatar
Default Clutch Problem Need Help!!!
My friend has a 95 Accord and he has no pressure at all in his clutch. We have replaced the clutch master cylinder and also the slave cylinder and also bled the system many times and it still wont build any pressure. We tested the master cylinder before putting it in and it worked fine. We are kinda stumped, does any one have any suggestions. Thanks
Old Jul 3, 2004 | 05:53 PM
f22b-dohc's Avatar
Default Re: Clutch Problem Need Help!!! (xpurespeedx)
this took me about an hr to bleed till it built presssure....
u guys take the tranny off? release bearing ok?
Old Jul 3, 2004 | 09:15 PM
Default Re: Clutch Problem Need Help!!! (f22b-dohc)
No we didnt remove the tranny, it should be ok. We bled it for like 15 min and it started to spit out fluid very slowly, do you think it will eventually start to build pressure?
slowaccord559
Dec 5, 2009 03:59 PM
jaywo_23
Oct 11, 2007 08:49 PM
phyzJunkieCivic
May 3, 2007 10:52 AM
T"u"Rtle
Apr 21, 2006 10:17 AM
xpurespeedx
Jul 11, 2004 03:04 PM
