Clutch problems
Old Apr 6, 2007 | 12:41 PM
phyzJunkieCivic's Avatar
From: Dont You Just Love Lynn Cops, Boston MA, USMA
Default Clutch problems
One of my friend are having problems with his tranny. It doesn't go into any gears, thats when the car is running. But when the car is off it goes into gear. When leaving it in gear and start up the car, it feels like it wants to go forward with out realeasing the clutch pedal.
Any idea will be helpfull
I think the problem would be the pressure plate, but really unsure.
Old Apr 6, 2007 | 12:43 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: Clutch problems (phyzJunkieCivic)
What year? If hydro, top off the clutch master cylinder and bleed the clutch slave cylinder.
Old Apr 6, 2007 | 12:46 PM
LoseRPunKx182's Avatar
Default Re: Clutch problems (Dogginator)
fill the transmission fluid
Old Apr 6, 2007 | 12:47 PM
Default Re: Clutch problems (LoseRPunKx182)
These are the thing we look at so far and replaced.
Top of fluid and bleed system
Changed tranny fluid
Check linkage and shifter
Changed the slave
Might be a bent fork or a screwed up pressure plate/clutch.
Old Apr 6, 2007 | 12:49 PM
Oh Dogginator its a 95 ls tranny hydro.
Old Apr 6, 2007 | 01:39 PM
knomexx's Avatar
probably a bad master cylinder
Old Apr 6, 2007 | 02:03 PM
dimwitrj's Avatar
I've got the same problem, changed out the slave and master and bled the system. I'm also guessing its the pressure plate. Doin a clutch job in a week.
Old Apr 6, 2007 | 02:17 PM
adamrich33's Avatar
sounds like the clutch fork is not seated on the throw out bearing
Old Apr 7, 2007 | 12:49 AM
Tranny is comeing off.
Old Apr 7, 2007 | 07:25 AM
Integra4lyfe069's Avatar
Default Re:
when going in first on my 99 ls i dunno if i have a hydro or cable clutch how do i find out?.. anyway going into first it like.... wants to like slip out of place and not engage but it does.. dunno wuts up
Old Apr 11, 2007 | 02:01 AM
problem fixx clutch spring fell off
Old Apr 13, 2007 | 04:53 AM
t3st's Avatar
Default Re: (phyzJunkieCivic)
im having some similar problem .. but when i start the car .. in neutral and no clutch pressed.. it starts vibrating .. and it stops when i press the clutch. even if put 1st gear or reverse and try to move on the car it does lil bit then stop and vibrates.. what could that be?
Old Apr 13, 2007 | 05:31 AM
Dogginator's Avatar
Daisy... Daisy...
Default Re: (t3st)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by t3st &raquo;</TD></TR><TR><TD CLASS="quote">im having some similar problem .. but when i start the car .. in neutral and no clutch pressed.. it starts vibrating .. and it stops when i press the clutch. even if put 1st gear or reverse and try to move on the car it does lil bit then stop and vibrates.. what could that be?</TD></TR></TABLE>
Does it vibrate in neutral once the car is warm? What fluid is in your transmission?
Old Apr 13, 2007 | 07:27 AM
t3st's Avatar
Default Re: (Dogginator)
valvoline 20w-50 is what i use for my transmision .. do u think it may need fluid ? .. i dunno if its only when its warm .. i know it did that when it was warm last night .. i stopped the car.. and when i tried to start it again it started doing that.. but it was working perfectly 10 mins.. before
Old Apr 13, 2007 | 08:42 AM
Dogginator's Avatar
Daisy... Daisy...
Default Re: (t3st)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by t3st &raquo;</TD></TR><TR><TD CLASS="quote">valvoline 20w-50 is what i use for my transmision .. do u think it may need fluid ? .. i dunno if its only when its warm .. i know it did that when it was warm last night .. i stopped the car.. and when i tried to start it again it started doing that.. but it was working perfectly 10 mins.. before</TD></TR></TABLE>
Switch to Honda MTF. 20w50 is too thick. The manual recommends 5w30 only as a temporary fluid.
Old Apr 15, 2007 | 04:00 PM
dimwitrj's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by phyzJunkieCivic &raquo;</TD></TR><TR><TD CLASS="quote">problem fixx clutch spring fell off</TD></TR></TABLE>
My problem fixed too, same exact thing.
Old Apr 23, 2007 | 06:00 PM
bow tie's Avatar
Default Re: (dimwitrj)
i have a similar problem with my b18c swap.
picture this:
your drivng and you come to a stop sign. you stop and try to pop it into 1st. you cant. you release and press the clutch again and still cant push it into gear. as you push the lever trying to get into 1st you notice that the rpm drops a little the harder you push. you finally shove it real hard into gear and the rpm drops to zero and the car stalls. when the car is off you can finally put it into 1st, you turn on the car w/ the gear in 1st but just pushing the clutch pedal down the car rolls foward (no hill). this is my problem... my clutch wont be here for 3 more days any ideas on what else might be wrong?
Old Apr 26, 2007 | 04:47 PM
dimwitrj's Avatar
Default Re: (bow tie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bow tie &raquo;</TD></TR><TR><TD CLASS="quote">i have a similar problem with my b18c swap.
picture this:
Does it go into any of the gears besides 1st? When one of the springs in my clutch came off it acted as you described with all of the gears. I didn't force it in like you did though but I'm pretty sure it would have stalled too cause the rpms went down as I tried to put it into gear.
Old Apr 29, 2007 | 10:06 PM
billyinse's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dimwitrj &raquo;</TD></TR><TR><TD CLASS="quote">
My problem fixed too, same exact thing.</TD></TR></TABLE>how tha hell do you fix that?
Old Apr 30, 2007 | 02:20 AM
new clutch?
Old Apr 30, 2007 | 08:36 PM
billyinse's Avatar
cant i drive with out a clutch?....nah but for real i dont want to buy a new clutch this sucks
Old May 3, 2007 | 10:52 AM
Sometimes you have to do things you dont want, life sucks. lol
blasterman87
Feb 18, 2010 05:09 PM
WTFINEEDBBQ
Nov 22, 2009 02:59 AM
MadCityLude
Aug 25, 2006 05:12 AM
ViZ
Sep 18, 2003 12:19 PM
BoostedD15B7
Feb 5, 2003 06:57 AM
