---HOW CAN U TELL WHEN V-TEC KICKS IN?---
Old Jul 2, 2004 | 06:56 PM
enochnich's Avatar
Default ---HOW CAN U TELL WHEN V-TEC KICKS IN?---
I have a 89 hf with a 93 SOHC V-tec D16Z6 in it but how can you tell when V-tec kicks in does it feel like it has a small turbo when it kicks in or what??
Also will D16A6 piston rods and pistons work in my D16Z6????
Old Jul 2, 2004 | 07:00 PM
Skinnypunk's Avatar
Default Re: ---HOW CAN U TELL WHEN V-TEC KICKS IN?--- (enochnich)
youll hear it...
Old Jul 2, 2004 | 07:24 PM
91civicEX's Avatar
its not as noticeable on the z6 but if it doesnt fall flat on its face above 5k then vtec is working
Old Jul 2, 2004 | 07:27 PM
mr. carpenter's Avatar
Default Re: ---HOW CAN U TELL WHEN V-TEC KICKS IN?--- (91civicLX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91civicLX &raquo;</TD></TR><TR><TD CLASS="quote">its not as noticeable on the z6 but if it doesnt fall flat on its face above 5k then vtec is working</TD></TR></TABLE>
i do not hear it on my z6 but right at 4000 rpm i'm thrown to the back seat. seriously, as stated the car should still feel strong at 5k.
Old Jul 2, 2004 | 07:31 PM
vtecn8ive's Avatar
Default Re: ---HOW CAN U TELL WHEN V-TEC KICKS IN?--- (mr. carpenter)
damn never had that feeling of being put back in my seat. But you can here it kick in. It makes a little noise.
Old Jul 2, 2004 | 07:36 PM
Default Re: ---HOW CAN U TELL WHEN V-TEC KICKS IN?--- (vtecn8ive)
not back in your seat, in the back seat. i barely have enough time to climb back to the front and shift. again i'm just kidding.
Old Jul 2, 2004 | 07:41 PM
sohcvtec66
Guest
Posts: n/a
u can hear vtec ingage with a clicking, dont use a6 cam, use a jdm d15b vtec camshaft, more agressive, better than a zex cam
eda6's Avatar
There someone on this board, i forget his name though.
For $40, he'll sit in your passenger seat and punch u
in the nuts when vtec kicks in. j/k
You'll notice a different sound from your exhaust when vtec kicks in.
Old Jul 2, 2004 | 07:48 PM
Default Re: ---HOW CAN U TELL WHEN V-TEC KICKS IN?--- (eda6 hb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eda6 hb &raquo;</TD></TR><TR><TD CLASS="quote">There someone on this board, i forget his name though.
yeah that guy would work too.
Old Jul 2, 2004 | 07:52 PM
crxgator's Avatar
your car will smoke the tires when vtec kicks in...
and then throw you into your seats and explode...
Old Jul 2, 2004 | 08:07 PM
ijjz's Avatar
Default Re: ---HOW CAN U TELL WHEN V-TEC KICKS IN?--- (crxgator)
when you feel like you are going 'ludicrous' speed, you hit vtec.
Old Jul 2, 2004 | 08:51 PM
Nature's Renewal's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr. carpenter &raquo;</TD></TR><TR><TD CLASS="quote">not back in your seat, in the back seat. i barely have enough time to climb back to the front and shift. again i'm just kidding.</TD></TR></TABLE>
omfg, that made my day. I might have to quote you in my signature
Old Jul 2, 2004 | 10:12 PM
DXDOHCVTEC's Avatar
Default Re: ---HOW CAN U TELL WHEN V-TEC KICKS IN?--- (krskid)
Normally I lose my grip on the steering wheel and if my hane is on the shifter I'll accidentally slam it in reverse (not good on trans) then my seat will break (i go through more seats that way)
Old Jul 2, 2004 | 10:38 PM
Malgerus's Avatar
Sohc D Series VTEC engines only have VTEC on the intake valves. That's why you don't hear the distinctive sound at the VTEC crossover. If you have an intake it may help you hear when VTEC engages, but otherwise it's not really noticeable.
Old Jul 2, 2004 | 11:03 PM
hammerdgolfer's Avatar
yes excatly, and when vtec turns off you will hear the blow off valve
if you want more performance upgrade your vtec wastegate
Old Jul 2, 2004 | 11:49 PM
Los.'s Avatar
youl feel alittle bit more kick around higher rpms and itl sound alittle different
Old Jul 2, 2004 | 11:51 PM
EL Vap133's Avatar
Since this has turned into a joke, it is now.........
sir_mugenpower
Nov 25, 2008 07:55 PM
lilredrocket83
Sep 9, 2007 09:58 AM
Frost_1097
66
Jan 15, 2007 07:00 PM
vtecspeed1320
11
Jan 22, 2006 07:55 PM
civicracer1993
Apr 5, 2003 03:07 AM
