Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Weight reduction for ITR
Old Jul 1, 2004 | 05:44 PM
nsxjr2's Avatar
Default Weight reduction for ITR
so far ive takin out:
power steering
a/c
rear wiper
power antenna
rear seats
spare tire
just wondering what else i can do to lose some more pounds
but i want to leave in the supports. My goal is to get around 2300 2250 pounds.
Old Jul 1, 2004 | 06:08 PM
Sean O'Gorman's Avatar
Default Re: Weight reduction for ITR (nsxjr2)
What class is this for? Most autocross classes wont allow many of those things to be removed.
Old Jul 1, 2004 | 06:12 PM
GSpeedR's Avatar
For what? If you're just loosing weight for the hell of it, then I'd try the ITR forum. If you have a racing class in mind, most will tell you to get a rule book.
Edit: ferkin slow *** computer
Old Jul 1, 2004 | 07:47 PM
1GreyTeg's Avatar
Cross reference this post for fun:
https://honda-tech.com/zerothread?id=913076
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSpeedR &raquo;</TD></TR><TR><TD CLASS="quote">
If you're just loosing weight for the hell of it, then I'd try the ITR forum.</TD></TR></TABLE>
He actually asked us first and got the same reasonable response till it went to whoring.
Old Jul 3, 2004 | 07:02 PM
ion_four's Avatar
Default Re: Weight reduction for ITR (1GreyTeg)
Depending on rules, etc. ditching the sun roof (as well as motor) and 'non moveable' windows for Lexan can lose about 70lbs. I believe Flex-a-lite makes direct replacement windows for the DC2. I would do this, but it's a no-no for street-mod and costs a bunch of money, to boot!
Old Jul 5, 2004 | 05:43 PM
Xian's Avatar
Default Re: Weight reduction for ITR (ion_four)
losing the sunroof is gonna be awfully hard (or easy depending on how you look at it)...
Christian, who never liked sunroofs anyway.
Old Jul 6, 2004 | 11:20 AM
D16autox's Avatar
wheels are always good for several unsprung pounds.
Old Jul 6, 2004 | 11:40 AM
Crack Monkey's Avatar
How silly do you want to get? There is a good thread on the Miata forum about weight reduction for SCCA Street Prepared. Some of the stuff is quite silly - guys are shaving hundreds of pounds legally off a lightweight roadster.
Old Jul 6, 2004 | 11:53 AM
Knestis's Avatar
Default Re: Weight reduction for ITR (Crack Monkey)
Once you have determined which accessories you need and don't need, take the wiring harness out, unwind it and chase out any wires that are no longer necessary.
Cut off all chassis and interior tabs for parts that you don't have to use (saved more than a few pounds on a Golf II rally tub this way).
Remove all of the undercoating, interior sound damper, and insulation.
Thin-walled Ti exhaust tubing saves a few pounds. Replace OE manifold with a light header.
There is excess material on the block, heads, intake manifold, gears, differential, and other cast or forged parts. Start trimming.
Parker Johnstone's Comptech IMSA Acura had windows that were thinner than stock - but still glass.
How serious are you? Strip it to the tub and acid dip it...
K
Old Jul 6, 2004 | 11:56 AM
Default Re: Weight reduction for ITR (Knestis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Knestis &raquo;</TD></TR><TR><TD CLASS="quote">Strip it to the tub and acid dip it...</TD></TR></TABLE>
I thought this was a bad idea unless there is a tube frame underneath or the tub is seam welded. Supposedly, the acid will eat away any adhesives used to bond the unibody together. Not sure where I heard this; pretty sure it was in a HT thread a while back.
Old Jul 6, 2004 | 12:13 PM
Knestis's Avatar
Sorry - you're right CM. Add "stitch weld chassis" to the to-do list.
K
Old Jul 6, 2004 | 07:49 PM
Mattamotor's Avatar
Type-R's never came with roofs and if they did the roof can come out in SM due to SP update backdate.
Old Jul 11, 2004 | 05:21 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: Weight reduction for ITR (Mattamotor)
u can swap out the 5 lug.....thats if u want too....i took my 5 lug off...saved like 45lbs of unsprung weight
https://honda-tech.com/zerothread?id=915556
RPRacing
May 10, 2005 04:19 PM
nsxjr2
Jul 3, 2004 12:09 PM
Scean
Mar 23, 2004 10:37 AM
sqwerz
Feb 15, 2004 07:22 PM
Todd00
Jun 21, 2002 10:56 AM
