what piston and rod combo fit into the D16A6?
Old Jul 1, 2004 | 12:33 PM
letholone's Avatar
Default what piston and rod combo fit into the D16A6?
like topic says, looking for a little bump in compression without going forged.
thanks.
Old Jul 1, 2004 | 01:12 PM
4drEF's Avatar
Keyboard Humorist
Default Re: what piston and rod combo fit into the D16A6? (letholone)
I believe it's the A1 pistons and stock A6 rods that you do for a bump.
If you are worried about snapping a rod, you can rebush some LS rods and notch the block and have a set of strong rods in there too.
Old Jul 1, 2004 | 01:13 PM
letholone's Avatar
how weak are the rods? i dont see this motor going above 8K.
estimate on compression with those pistons in?
Old Jul 1, 2004 | 01:18 PM
Ash J. Williams's Avatar
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
stock rods, P29 pistons
stan
CanadianEF9
Nov 8, 2010 04:16 PM
boost fed ls
Jan 29, 2005 04:20 AM
dragaholic
Apr 11, 2004 03:24 PM
B18B1DOHC
Sep 16, 2003 10:10 PM
