98 Hatch with check engine light
Old Jun 30, 2004 | 12:55 PM
c8r9x's Avatar
Default 98 Hatch with check engine light
hey my brothers check engine light came on and the temp. needle goes up when he is just idleing like at a stop light, but it only does it 2 or 3 times a day. No sensors are broken physically, anyone have this problem, or know what it is?
Old Jun 30, 2004 | 01:07 PM
emoney9's Avatar
Default Re: 98 Hatch with check engine light (c8r9x)
find out what code its throwing...you do this by using apaper clip and jumping 2 wires together...down by your ecu is a 2 pin plug (blue) and its covered by a green rubber cover....make the paper clip into a "U" shape and plug it into the blue plug...do this while the car is running....and count how many times you check engine light flashes...if it flashes long then followed by short flasshes thats a 2 digit code for example: 1 long flash, followed by 7 short flashes= code 17....if its a single digit it will flash short. example" 5 short flashes= code 5...go try this out and let me know
Old Jul 5, 2004 | 01:17 PM
c8r9x's Avatar
Default Re: 98 Hatch with check engine light (emoney9)
do you check it the same way that you check an EG code? because the car is an EK and i heard that you had to use the "box" to check codes on obd2
Old Jul 6, 2004 | 10:24 AM
emoney9's Avatar
its the same way for an eg and ek...you can jump the connector with a paper clip
ethos0518
Aug 13, 2011 07:36 AM
I-4
Jun 5, 2007 03:29 AM
DeDonDeRosa
Oct 2, 2004 05:22 PM
Slow
Nov 20, 2002 11:11 PM
Todd00
May 24, 2002 07:04 PM
