Got my shotblock together *pic*
Old Jun 29, 2004 | 09:10 PM
Blind-Fashion's Avatar
Default Got my shortblock together *pic*
Well here she is..
Used JE 9.0:1 pistons ( took them to a machine shop, said they are mint )
Eagle rods
Type R crank
Golden eagle sleeves
Napa main bearings ( all spec'ed out to .0015 perfect!! )
OEM rod bearings
Everything is going well so far, just waiting for the arp headstuds! 450 + hp here i come!
-Josh
Modified by Blind Fashion at 11:53 PM 6/29/2004
Old Jun 29, 2004 | 09:26 PM
ATS*Mark's Avatar
OG triple OG
Default Re: Got my shotblock together *pic* (Blind Fashion)
cool!
Old Jun 29, 2004 | 09:52 PM
Rod.'s Avatar
Default Re: Got my shotblock together *pic* (Hella_JDM)
I give you 2 for building your own motor. I wish I had enough confidence to do that.
Old Jun 29, 2004 | 10:01 PM
AK94GSR's Avatar
Default Re: Got my shotblock together *pic* (redturbocivic)
looks good mang!
oh and is your block painted black???
Old Jun 29, 2004 | 10:09 PM
MustangPunk302's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redturbocivic &raquo;</TD></TR><TR><TD CLASS="quote">I give you 2 for building your own motor. I wish I had enough confidence to do that.</TD></TR></TABLE>
It's not hard at all....
Old Jun 29, 2004 | 10:21 PM
block is painted low gloss black.. engine enamal stuff..
Thanks for the comments guys!!
Old Jun 29, 2004 | 10:26 PM
Default Re: (Blind Fashion)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blind Fashion &raquo;</TD></TR><TR><TD CLASS="quote">block is painted low gloss black.. engine enamal stuff..
Thanks for the comments guys!!</TD></TR></TABLE>
I like the looks of it ... Nothing fancy, nice clean look.
Old Jun 29, 2004 | 11:14 PM
boosted_dc2's Avatar
Default Re: (MustangPunk302)
god damn that looks like a big feed. also i am going to recomend a couple things to you.
1. dont tee of the back of the block like that, the vibrations can cause it to snap of INSIDE your block and it is a biatch to get out. use a fitler adapter, or run an aditional line straight from the block to the tee and mount it on your firewall.
2. ditch the pcv system, get a catch can setup on there. the fumes will kill your power, unless you have emmisions.
other than that looks good, i like the black block i wish i did that color instead of silver.
Landon
Old Jun 29, 2004 | 11:22 PM
the block fitting will not break, its steel and hugs the block.. lol, i even put one in my old d series blcok and tried to brake it off.. its ok...
anyways, how do i ditch the can? i mean there is a huge *** hole in the block.. if someone could help me out that would be great.
Old Jun 29, 2004 | 11:27 PM
i guarantee you it CAN break, ive done it and it sucks really really really bad.
do a search on catch can and pcv youll find a **** load of stuff. but i am running an endyne breather kit and it comes with all the stuf you need.
http://www.theoldone.com/components/breather/
you can do it for cheaper by getting the parts yourseld but i didnt feel like dealing with it.
Landon
Old Jun 30, 2004 | 06:52 AM
Rod.'s Avatar
Default Re: (boosted_dc2)
you can do a endyn catch can system
Old Jun 30, 2004 | 06:58 AM
Turbocivic94's Avatar
Default Re: (redturbocivic)
I have the catch can, does anyone know how to install it.
Old Jun 30, 2004 | 07:00 AM
m R g S r's Avatar
Can you just let it vent into the atmosphere instead of spending that $$ on a catch can. I really don't have to worry about passing emissions, so will that work?
zex_cool
Nov 12, 2008 05:43 PM
zex_cool
Nov 3, 2008 09:00 AM
typeR#1141
Aug 11, 2007 04:16 PM
Bc3
Dec 26, 2006 11:35 AM
Sketch_hs
Mar 1, 2006 07:07 PM
