rebuilt motor...solid CEL?
Old Jun 29, 2004 | 07:38 PM
crxY-49's Avatar
Default rebuilt motor...solid CEL?
I've got a problem with my car. I rebuilt my d16a6 with some internal goodies and everything is in the car and hooked up. Now my problem is the car will only crank over...no spark...no fuel. I tried to swap in a good main relay and no dice. The weird thing is when I turn the key to the on position the light will blink very fast and change pace and sometimes become solid, and sometimes even show nothing. I can't hear my fuel pump prime either. Does this sound like a faulty ecu, or could it be a sensor or messed-up wiring causing this.
oh yea...its a pm6 ecu.
Thanks guys. - Joe
Old Jun 30, 2004 | 11:54 AM
crxY-49's Avatar
Default Re: rebuilt motor...solid CEL? (crxY-49)
Old Jul 1, 2004 | 01:11 PM
PreStaged12s's Avatar
A Solid check engine light has to do with the ECU, either it isnt pluged in correctly which is usually the problem. Just unplug and replug making sure you pushed the plugs in all the way. If there still is a solid CEL, see if you can get another ECU from a friend or something cause like I said solid CELs are ECU related.
Old Jul 1, 2004 | 03:18 PM
97mini-me's Avatar
My CEL was solid when i had the jumper wire in it and wasn't throwing any codes. Go figure....
the.tetrix
Aug 15, 2017 03:58 PM
jpar195
Apr 7, 2008 12:01 PM
drumminforev
19
Oct 6, 2006 12:12 AM
Soled Out
Jan 23, 2003 09:44 PM
