What is the best Head for Vtec turbo Gsr vs B16a2????
Old Jun 29, 2004 | 09:24 AM
Lilkong's Avatar
Default Which Head should I use for Vtec turbo Gsr or B16a2????
This going to be a turbo appl. I was wondering what head should I use. I have both heads but my pipings are for a B16 setup. The pistons I'm using are CP 9:1 in a Gsr block.
Modified by lilkong at 6:36 PM 6/29/2004
Old Jun 29, 2004 | 10:18 AM
Sliced Beard's Avatar
Default Re: Which Head should I use for Vtec turbo Gsr or B16a2???? (lilkong)
for one you will have lower compression witht eh b16 head and another the b16 head flows better
my preferred combonation would be the GSR block with the b16 head and the GSR cams unless you plan on getting aftermarket turbo cams. GSR cams are excellent turbo cams and the b16 has larger valves
Old Jun 30, 2004 | 03:17 AM
Lilkong's Avatar
Default Re: Which Head should I use for Vtec turbo Gsr or B16a2???? (dirtyd463)
BUMP
Old Jun 30, 2004 | 06:13 AM
mmuller's Avatar
Mad Scientist
gsr head
Old Jun 30, 2004 | 09:00 AM
Lilkong's Avatar
Default Re: Which Head should I use for Vtec turbo Gsr or B16a2???? (mmuller)
Should I just get a Skunk 2 manifold for the Gsr head then. But then again I already spent $3300 building my bottom end. Need to sell one or the other to get a s200b managment.
Old Jun 30, 2004 | 09:25 AM
you should buy my GSR head and port the stock manifold
Old Jun 30, 2004 | 09:40 AM
Lilkong's Avatar
Thanks anyways, I already have them both. Just can't decide which one would I benefit from.
snowpro127
Apr 10, 2008 02:01 PM
dixie Normas7
Apr 28, 2006 08:28 AM
teefunk01
Oct 9, 2005 07:30 AM
blk007
Jul 14, 2005 10:20 AM
