B16 or GSR head on a GSR short block for Turbo ?? STRAIGHT GSR TURBO VS POORMANS R TURBO
476 whp / 323 tq @ 17 PSI
B16 head or GSR head for turbo on a GSR short block?? which is better at stock and flows better for turbo?? PROS/CONS, thanks!
B16 head over the GSR stock, built and ported don't matter. Reason being, I don't have a pic to show you but I know you can find some, compare the combustion chambers on the B16 and the GSR, you'll notice the B16's is a complete circle where at the GSR's looks as if the sides of a circle where cut off. Because of this, you'll have a littler higher compression with the GSR head. The ports on the B16 are slightly larger as well making for a little better flow. As far as the intake manifold... The flow on the GSR mani SUCKS! Where as the flow on the B16's is pretty good! That is, stock vs stock!
Re: (BLKTeg94)
Who said squishbands are a bad thing? Lots of people will argue that the pentroof-design inherent in the GSR head will help to reduce knock and enhance efficiency due to the tumble/swirl-effect when the piston closing to TDC pushes the air/fuel-mixture into the centre of the combustion chamber.
Re: (Oyvind Ryeng)
interesting points, seems to me that the b16 head could outperform the GSR head but the GSR head would be more reliable obviously
b16 head flow is only a bit better my a couple CFM's
and the casting on pr3 head arent the best either because of the old molds
i'd take a gsr head, beause of better combustion, better port entry angle, and a better casting
Re: B16 or GSR head on a GSR short block for Turbo ?? STRAIGHT GSR TURBO VS POORMANS R TURBO (JDM tu
I would go with a GS-R head for the reasons listed above^^^ and because I already have one.
EM1OwnerSi
11-09-2006 06:25 AM
