Oil pressure gauge
What questions do you have specifically? Are you using an electric guage?
I have an eletric autopower oil pressure guage in my car, it wasn't 'easy' to install, but it isn't that difficult. I just T off the block where the stock oil pressure sending unit bolts in, and ran my line off of it.
well, go look under the car and see if you still think so.
get something better than brass tee, the port loves to stripes and crack when you putting extra weight to it.
the oil guage sensor is located above the oil filter, so you'll need to get it from underneath the car.
size 24 deep socket used to remove the sensor, you'll need a T fitting. may honda guys use a brass tee there for oil supply. Brass Tee are just as ghetto as it gets, they sell better fitting now(after abunch of stripped and cracked port on the block).
no, there is no hose going to the sensor, just a wire. You unbolt the stock sensor from the block. Screw in the T, using the proper fittings into the block, screw the sensor into one side of the T and re hook the wire, hook a line to the other side of the T.
I used a SS braided line, to run oil to my oil pressure sending unit. I had a rubber line on it, it lasted 2 days before it split in 1/2 and sprayed oil everywhere.
you could use an nylon line you can get at pepboys,kragen,autozone the line is usealy next to the manual gages or brass line but i you bend brass to much it will break in two the nylon is more flexable and user friendly
Cool, thanks for all the tips guys, I think I should be able to figure it all out now!
If not I will be back with more anoying questions..
