Personal Experience with turbo reliability?
Old Nov 18, 2001 | 07:01 AM
Prelussion's Avatar
Default Personal Experience with turbo reliability?
Ok, I did a search but only found one topic that would help, and none of it was personal experience with the reliability. So what i'm wanting to know is how reliable have the setups w/ stock internals been, then how reliable have the setups w/ built internals been, and how is the engine built. I won't be dragging my car all too much, and i'll only be running about 7-9psi on eagle rods, custom low c/r pistons, and i'm getting all my bearings and what not replaced. Also I've heard of block decking. But i'm not sure how this would help me. Thanks ahead of times for any replies.
-Travis
[Modified by Prelussion, 4:03 PM 11/18/2001]
Old Nov 18, 2001 | 10:59 AM
Prelussion's Avatar
Default Re: Personal Experience with turbo reliability? (Prelussion)
Come one guys, everyone with a turbo can answer this question.
Old Nov 18, 2001 | 11:01 AM
immortal's Avatar
Banned
may just be bad luck but......
my cars been nothing but problems with reliability since i got my turbo
i think its all because of my cracked radiator overheating / fuel regulator breaking though.
Old Nov 18, 2001 | 11:55 AM
Etylorcen's Avatar
Default Re: Personal Experience with turbo reliability? (immortal)
For a b18b 7-9psi daily is fine on stock internals...just get it tuned. All about tuning when it comes to turbo...the stock block can take a lot, even the b18c.
Old Nov 18, 2001 | 04:55 PM
Prelussion's Avatar
Default Re: Personal Experience with turbo reliability? (Etylorcen)
ok 68 people have viewed this and only 2 other people have posted.
Old Nov 18, 2001 | 05:23 PM
Mike D's Avatar
ok here is the deal, i dont have a turbo(but will sometime in teh future) and i dont have any personal experience with others who did, but here's what i think.
On stock internals, 7-9 psi is good for reliability. That limit is liberal to put it best. But, as mentioned above, you have to pay close attention to your engine. You must tune it. This is the most critical thing of all. I dont think that there is any reason you shouldnt get 30k to a WELL MAINTAiNED turbo set-up.
If this is what you want to do, you just have to go the extra mile to be on top of your maintenance. change the oil, properly gapped plugs will make a huge difference, etc.
I beleive that if you dont actually put in new rods and slugs, it wuold be worth it to just have the engine rebuilt to stock specs to make sure everything is gravy, unless you feel your engine is in well enough shape.
but, either way it comes down to tuning. if you have to fork out 400 bucks for dyno time then so be it.
so to answer your question, yes i believe that any turbo set up can be reliable. Obivoulsy if you blast 9 psi into an engine with 200k on it then im not sure how long it might last.........you get what i mean.
Mike
Pellegrini808
Aug 30, 2013 10:10 PM
jakoh77
Sep 29, 2011 05:01 AM
rylflsh1806
May 19, 2009 02:33 PM
JayIntegra
Sep 13, 2007 09:02 PM
TheSwift1
Jun 25, 2002 10:23 PM
