ls tranny on b16 ?
Old Jun 27, 2004 | 08:08 PM
Lshatchy91's Avatar
Default ls tranny on b16 ?
I was going to put a ls tranny on a b16. what are the pros and cons of that .???
Old Jun 27, 2004 | 08:27 PM
EL Vap133's Avatar
Default Re: ls tranny on b16 ? (Lshatchy91)
No pros, just cons. You're not gonna like it.
Old Jun 27, 2004 | 09:03 PM
Loaded Butane's Avatar
Default Re: ls tranny on b16 ? (EL Vap133)
Only pro would be if thats the only tranny you have to get your car movin.
Old Jun 27, 2004 | 09:06 PM
Gant's Avatar
Default Re: ls tranny on b16 ? (Loaded Butane)
pros= better gas mileage since the ls 5th gear would keep it low in the rpms instead of a b16 5th gear, if you like freeway battles then the long *** gears would be good for you, (my friend has a DA integra with a gsr motor and still use's his ls transmission and it hauls on the freeway)
cons= well u know the cons
Old Jun 27, 2004 | 11:13 PM
d16X's Avatar
yea the ls tranny has long *** gears i would just use the b16 tranny unless u like that high speed highway races
Old Jun 30, 2004 | 02:42 PM
Circuit Star-29's Avatar
Default Re: (d16X)
LS has alot longer gears than a B16. LS is better for turbo. B16 is best for all motor. Heres a web site with the gear ratios.
http://www.bseries.net/html/specs/btrannyspecs.php
Old Jun 30, 2004 | 05:36 PM
mar778c's Avatar
Community Builder
Community Influencer
What he said.
Seriously, LS if your going to turbo. You can use the LS on a stock b16 but you will lose a lot more than you should. I tried and it was not pleasant.
Old Jun 30, 2004 | 07:17 PM
Lshatchy91's Avatar
Default Re: (mar778c)
what year ls tranny did u guys use??? does it matter i have a 91 ls trany.
Old Jun 30, 2004 | 07:47 PM
Jester88Si's Avatar
Its gonna be slow, B16 already kinda sucks pulling from a dead stop with short geared tranny...couldn't even imagine it with LS gears.
Old Jun 30, 2004 | 11:23 PM
Default Re: (Lshatchy91)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lshatchy91 &raquo;</TD></TR><TR><TD CLASS="quote">what year ls tranny did u guys use??? does it matter i have a 91 ls trany.</TD></TR></TABLE>
There really isn't that much difference between the Cable ls trannies and the Hydro. You'll have a slightly higher final drive. Good tranny but only if TURBO. In your case, I would find a S1 or a Y1 (First Gen B16) . You'll be better off, but if you want to go turbo and have serious plans for it in the future then use the LS. Good luck
boostedefhatch
22
Jun 28, 2010 01:30 PM
hatch96y7
Aug 16, 2007 10:32 PM
2wheelhunter
Dec 28, 2006 05:56 PM
a2dadamm
Dec 29, 2005 01:24 PM
mrchris386
Nov 24, 2003 07:25 PM
