blead my brakes and pedal is still soft... bad MC?
Old Jun 27, 2004 | 03:36 PM
euclid's Avatar
Default blead my brakes and pedal is still soft... bad MC?
hey guys, i blead my brakes and the pedal is still feeling soft while i drive the car.
when i finished bleeding them the pedal felt rock solid, then i started up and drove it and it felt soft again, any possible expalnations. my ebrake was engaged when i did the bleeding, could that be the problem?
could it be a bad master cylinder? is there a way to diagnose it? thanks
Old Jun 27, 2004 | 04:41 PM
Im_In_There's Avatar
Default Re: blead my brakes and pedal is still soft... bad MC? (euclid)
bleed them again. You propably unpurposely let air in the system.
It happened to me, and i thought as well that there was something wrong, but bleeding them again properly solved the problem.
good luck
Old Jun 27, 2004 | 05:29 PM
Bbasso's Avatar
I always make sure the e-brake is down when I do my flushes... I dunno if it matters.
drive it and make sure you get the ABS to work a few times before you re-bleed the system, also I use the wood and hammer trick on the calipers to make sure there no bubbles sticking.
Old Jun 27, 2004 | 05:41 PM
SlapSmak's Avatar
make sure you bleed with the engine running, this way the ABS is being actauted. have bled many times (50+) after races and found out a long time ago, engine off=spongy pedal
Old Jun 27, 2004 | 09:33 PM
euclid's Avatar
Default Re: blead my brakes and pedal is still soft... bad MC? (SlapSmak)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SlapSmak &raquo;</TD></TR><TR><TD CLASS="quote">make sure you bleed with the engine running, this way the ABS is being actauted. have bled many times (50+) after races and found out a long time ago, engine off=spongy pedal </TD></TR></TABLE>
thanks for all the suggestions.
i think the vacuum in the booster from the intake manifold has something to do with it, bleed the brakes with the motor off then the brakes are not boosted, then whent the car is running and vacuum is boosting the brakes it makes them spongier b/c less efoort is required to use them.
hopefully thats it, i am 98% sure i did them correctly and did not intoduce air inadvertantly.
Old Jun 27, 2004 | 10:10 PM
R you serious's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by euclid &raquo;</TD></TR><TR><TD CLASS="quote">hey guys, i blead my brakes and the pedal is still feeling soft while i drive the car.
could it be a bad master cylinder? is there a way to diagnose it? thanks</TD></TR></TABLE>
did you just change your pads? if so, the pads probably arent bedded.
Old Jun 27, 2004 | 10:57 PM
euclid's Avatar
Default Re: blead my brakes and pedal is still soft... bad MC? (R you serious)
axxis ultimates with about 5k on them, fully bedded compliments of turn 1 at limerock.
the brakes are working really well, there is just more pedal movement than i would like. the first inch or so feels like slop... like with a clutch pedal that has not been adjusted.
Old Jun 28, 2004 | 12:29 AM
cheezthis's Avatar
My brakes are like that, and I'm sure my MC is going out. It has a 139k miles on it. It works, but I hit it hard when going into turns.
Old Jun 28, 2004 | 08:37 AM
Flux's Avatar
Default Re: blead my brakes and pedal is still soft... bad MC? (cheezthis)
I have never heard of bleeding the brakes while the motor is running. I don't, and it works fine. Like somebody said, try tapping on the caliper with a rubber mallet or something while bleeding to get the stubborn bubbles out if there are any.
Also, I have found that driving around for a few days usually helps what was originally a 'soft-ish' pedal.
Old Jun 28, 2004 | 09:05 AM
RealTypeR2's Avatar
Default Re: blead my brakes and pedal is still soft... bad MC? (Flux)
You bleed the brakes when the engine is off. If your master cylinder is bad, the best way to check out, is to look at it mounted to the booster in the engine bay. If you see any signs of leakage around the master cylinder and the booster, your MC is going bad.
Old Jun 28, 2004 | 10:29 AM
typer_801's Avatar
Default Re: blead my brakes and pedal is still soft... bad MC? (RealTypeR2)
I typically bleed with the ignition energized (motor off). My VW required it and some of the F-bodies do as well to get a good bleed. I've done every bleed in the ITR now too (4) and I've still got a rock hard pedal &lt;knocking on wood&gt;
Old Jun 28, 2004 | 10:36 AM
uNF$@#!'s Avatar
Default Re: blead my brakes and pedal is still soft... bad MC? (typer_801)
a good sign that mc is going bad is if you bare down on the brakes and they slowly but surely give way til the pedal is on the floor.
Old Jun 28, 2004 | 10:48 AM
RTW DC2R's Avatar
cant you turn the car off, pump the brake a few times and see if it gets harder and harder to push? is that to test the MC or something else?
Old Jun 28, 2004 | 11:24 AM
euclid's Avatar
Default Re: (RTW DC2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTW DC2 &raquo;</TD></TR><TR><TD CLASS="quote">cant you turn the car off, pump the brake a few times and see if it gets harder and harder to push? is that to test the MC or something else?</TD></TR></TABLE>
when the car is off the pedal stays firm
Old Jun 28, 2004 | 11:28 AM
Big Phat R's Avatar
Hey Euclid - do you still have the dustshields on your brakes?
Take em off - makes a BIG difference
Old Jun 28, 2004 | 12:03 PM
George Knighton's Avatar
H-T Order of Merit
OK, this is a new one on me. Are you sure about this? You're not joking?
Old Jun 28, 2004 | 12:11 PM
euclid's Avatar
Default Re: blead my brakes and pedal is still soft... bad MC? (Big Phat R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Big Phat R &raquo;</TD></TR><TR><TD CLASS="quote">Hey Euclid - do you still have the dustshields on your brakes?
Take em off - makes a BIG difference</TD></TR></TABLE>
i dont want my balljoint boots to melt, can i shield them?
Old Jun 28, 2004 | 12:50 PM
Big Phat R's Avatar
i dont want my balljoint boots to melt, can i shield them?</TD></TR></TABLE>
There's quite a bit of airflow around them - you could always duct more air to the area if needed.
I wouldn't worry about the boots melting per se - but the payoff is more even rotor cooling (esp the inner pad which works the hardest with the single piston R setup) and lower temps of the brake fluid.
Just inspect the boots regularly
Old Jun 28, 2004 | 12:54 PM
euclid's Avatar
thanks i will give it a shot, can i remove them without pressing out the hub? it seems like they have to be cut away.
Old Jun 28, 2004 | 12:59 PM
Flux's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by euclid &raquo;</TD></TR><TR><TD CLASS="quote">thanks i will give it a shot, can i remove them without pressing out the hub? it seems like they have to be cut away.</TD></TR></TABLE>
https://honda-tech.com/zerothread?id=458127
https://honda-tech.com/zerothread?id=68225
deanh22a
Honda Civic (2001 - 2005)
Jan 29, 2017 05:32 AM
steve55super77
Dec 9, 2012 01:10 PM
roger93si
Sep 4, 2007 01:10 PM
bb4ninja
Jun 17, 2006 06:39 PM
onyx00
May 18, 2004 05:13 PM
