Brake Problem!!!!!!
Old Aug 29, 2007 | 02:22 AM
roger93si's Avatar
Default Brake Problem!!!!!!
I have a 94' integra with abs. The problem that im having is when i apply my brakes either moving or parked, the pedal slowly sinks to the floor! While the car is off i press the pedal and it feel stiff, like normal. but when its on 7/10 times it will sink. Now i checked for leaks and fluid levels, both the master and abs have proper fluid. I havent taken the wheels off and checked but i will today. Another thing i noticed is that when i press the pedal fast,(slamming on brakes), i feel the car grab on the right side but the left side doesnt so the car will pull. any advice on what it could be. thanks guys!
Old Aug 29, 2007 | 06:22 AM
PrinceAli132's Avatar
Default Re: Brake Problem!!!!!! (roger93si)
Rebleed the system to make sure you have no air in the lines. Also, as for one side grabbing check the caliper pistons to make sure they are not seized.
Ali
Old Aug 29, 2007 | 07:27 AM
lmike6453's Avatar
this happened on my last car(supercharged bonneville)....it was the master cylinder, and it came w/ the reservoir
Old Aug 29, 2007 | 02:28 PM
roger93si's Avatar
havent had time to check but ima do it right now...
Old Aug 30, 2007 | 04:32 PM
roger93si's Avatar
Default Re: (lmike6453)
dam couldnt find nothing wrong. no leaks calipers fine, pads fine,.. and its still doing it. could it be my abs system going otu? or my master and booster going out?.. (no abs light on)
Old Aug 30, 2007 | 04:49 PM
SleeperGSR's Avatar
Default Re: (roger93si)
did you bleed your brakes???? any work done to your brakes recently?
Old Aug 31, 2007 | 12:07 AM
roger93si's Avatar
Default Re: (SleeperGSR)
yea i bled them.. no air.
no work done recently...
but b4 what i did notice was that every now and then when i would come to a stop, my pedal would go down to the floor..
ima change my master and see what happens.....
Old Sep 4, 2007 | 01:10 PM
roger93si's Avatar
Problem fixed!
]<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lmike6453 &raquo;</TD></TR><TR><TD CLASS="quote">this happened on my last car(supercharged bonneville)....it was the master cylinder, and it came w/ the reservoir</TD></TR></TABLE>
Yep it was the master all along. thanks guys for the help.
deanh22a
Honda Civic (2001 - 2005)
Jan 29, 2017 05:32 AM
jaideep_asokan
Oct 2, 2007 09:42 AM
digitalayon
Mar 13, 2005 02:48 AM
10K2HVN
Jan 18, 2003 12:09 AM
dustin
Jul 29, 2001 08:28 PM
