4 u turbo folks
Old Jun 26, 2004 | 05:31 PM
MNsnowdaboy's Avatar
Default 4 u turbo folks
like it says, my turbo doesnt spin even at idle. Thought it was the turbo bought an new one and same scenerio. Car would start and idle fine, but the turbo is not moving. Could it be te valves are loose and cause it not to spin? compression and everything is fine. Need some expertise help. Any thoughts turbo folks......
Old Jun 27, 2004 | 03:47 AM
Fobtions's Avatar
Default Re: 4 u turbo folks (MNsnowdaboy)
it never spins at idle or after it warms up after driving it?
ive seen most, not turn at first but after the oil has run through it they spin rather freely.
also, if this was a brand new turbo. did u make sure to crank the car without the distributor plugged in, so as not to fry the bearings in the turbo with no oil pressure.
Old Jun 27, 2004 | 06:36 AM
svmnredracr's Avatar
i've crank it long enough for the oil to reach the turbo, and i didnt have to unplug the distributor, my swithes for the motec/msd was off. just pushed the start button and let it cranked.. any more suggestions.
Old Jun 27, 2004 | 10:50 AM
full Circling's Avatar
From: That's the wrong tone... I'm Skunk2 certified.
^^^start button = the pimpness
Old Jun 27, 2004 | 01:12 PM
GZERO's Avatar
Default Re: (MugenDude)
check your waste gate to see if is stuck open and check for holes in the manifold
Old Jun 28, 2004 | 04:43 AM
Default Re: (GZERO)
wanna thank yall for the info and yeah the wg is shut same as the bov mani is good no leaks
Pellegrini808
Sep 30, 2013 03:56 PM
turboman2.2
Apr 30, 2010 07:05 AM
PINKS
Aug 28, 2006 08:54 PM
Vtec92Civic
Apr 17, 2004 07:21 AM
nortel
Feb 11, 2003 12:33 PM
