Oil and carbon deposits inside IM and TB
Old Jun 26, 2004 | 01:59 PM
RTW DC2R's Avatar
Default Oil and carbon deposits inside IM and TB
What would that tell you? After taking off my head, IM and TB, its literally like wet soot inside my IM and BEHIND the TB butterfly, NOT in front of it. The fact that is behind it makes me wonder. On the air intake side of the TB its pretty damn clean so I dont think its a result of the crank case vent. I had recently replaced the crank case vent hose with a breather filter anyway. My car USED TO burn a lot of oil before it blew up. Do you think it could have been clean and only happened as my motor blew up?
Old Jun 26, 2004 | 05:47 PM
RTW DC2R's Avatar
Default Re: Oil and carbon deposits inside IM and TB (RTW DC2)
wow this forum sucks now. where are all the techies at nowadays?
Old Jun 26, 2004 | 06:51 PM
magic hat #9's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTW DC2 &raquo;</TD></TR><TR><TD CLASS="quote">wow this forum sucks now. where are all the techies at nowadays? </TD></TR></TABLE>
you give the board 4hrs to respond on a saturday evening? why ain't your loser *** out banging chicks?
Old Jun 26, 2004 | 06:53 PM
BlueR's Avatar
Default Re: Oil and carbon deposits inside IM and TB (magic hat #9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by magic hat #9 &raquo;</TD></TR><TR><TD CLASS="quote">
you give the board 4hrs to respond on a saturday evening? why ain't your loser *** out banging chicks? </TD></TR></TABLE>
bc his motor looks like mine
Old Jun 26, 2004 | 07:23 PM
vtec.dc2's Avatar
did you run a catch can setup? maybe it got there from pcv to IM hose
Old Jun 26, 2004 | 07:31 PM
RTW DC2R's Avatar
1) because Im happily taken. this board used to be very fast no matter what day or time. you could aways get an answer or atleast a response. oh well.
2) because what marc said
3) no I didnt have a catch can set up.
like seriously its rediculously oily and smudgey. that would definitely explain the shitty HP numbers, black smoke from the exhaust under WOT, and oil burning so much. Just not sure what caused it. I was guessing PCV valve as well since that was the only other real option, but I dont know much about that valve and how it works.
Old Jun 27, 2004 | 04:39 AM
SlapSmak's Avatar
The PCV dumps directly inot the manifold, it greatly increases chances of detonation if it is not functioning correctly since it is venting oil into the cyninders via the IM. Oil fumes light off very quickly which , yes, could have been part of your HP # problems. A catch can would intercept the fumes and 'catch' all the oil which was once making into your intake tract. If your car was running, you can use Sea Foam cleaner and spray it into the throttle body opening to clean all that **** out. Makes a smoke screen your neibors won't believe, but cleans the intake tract out nicely.
Old Jun 27, 2004 | 05:08 AM
DutchITR1689's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTW DC2 &raquo;</TD></TR><TR><TD CLASS="quote">What would that tell you? After taking off my head, IM and TB, its literally like wet soot inside my IM and BEHIND the TB butterfly, NOT in front of it. The fact that is behind it makes me wonder. On the air intake side of the TB its pretty damn clean so I dont think its a result of the crank case vent. </TD></TR></TABLE>
It's normal that it's behind the TB, but it shouldn't be too much. On the intake side it should be clean.
Old Jun 27, 2004 | 05:52 AM
DA6righthand's Avatar
Default Re: Oil and carbon deposits inside IM and TB (SlapSmak)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SlapSmak &raquo;</TD></TR><TR><TD CLASS="quote">The PCV dumps directly inot the manifold, it greatly increases chances of detonation if it is not functioning correctly since it is venting oil into the cyninders via the IM. Oil fumes light off very quickly which , yes, could have been part of your HP # problems. A catch can would intercept the fumes and 'catch' all the oil which was once making into your intake tract. If your car was running, you can use Sea Foam cleaner and spray it into the throttle body opening to clean all that **** out. Makes a smoke screen your neibors won't believe, but cleans the intake tract out nicely.</TD></TR></TABLE>
...is all of this safe on all of the internals? does harm anything?
Old Jun 27, 2004 | 06:38 AM
uNF$@#!'s Avatar
like seriously its rediculously oily and smudgey. that would definitely explain the shitty HP numbers, black smoke from the exhaust under WOT, and oil burning so much. Just not sure what caused it. I was guessing PCV valve as well since that was the only other real option, but I dont know much about that valve and how it works. </TD></TR></TABLE>
1) daddy please go easy?
2) marc is out banging lots of chicks uh i mean his gf
3) when banging chicks, catch cans are definately required, unless you prefer a mess
tom - who thinks RJ will go "BAN!!!" if he sees this thread
ImPuLsIvE
Dec 10, 2008 06:26 PM
YoungKadafi
27
Aug 13, 2006 11:45 PM
2stockrocketz
Apr 13, 2004 09:22 PM
lazykiwi
Nov 3, 2003 11:45 AM
jerky
Jun 23, 2003 11:00 AM
