short shifter problem
Old Jun 26, 2004 | 12:11 PM
Civic92Turbo's Avatar
Default short shifter problem
after i'd install my short shifter it hits my exhaust and i can go into first and 3rd.... does any one have same problem as i do? what wouls you do? buy a new shifter like Skunk2/Dc sports? or .......
My set up
B16a
Car sound 2.5
apexi Full system Dunk
Tenzor R Shifter
Old Jun 26, 2004 | 12:13 PM
Dancing is Forbidden's Avatar
Default Re: short shifter problem (Civic92Turbo)
Did you not put the two rear linkage bolts back in?
Old Jun 26, 2004 | 12:35 PM
yep i install many short shifter into other EG's but mine dident fit right for some reason..
Old Jun 26, 2004 | 03:47 PM
HondaFanatic708's Avatar
From: San Diego, I miss Chicago, but love SD, CA, US of fuckin A
Default Re: (Civic92Turbo)
The answer is: You bought TenzoR, thats almost as bad as putting APC on your car (but not as bad). You didn't have any problems shifting before you installed the short shifter? One problem I have found with short shifters is they throw off the balance needed for precise and trouble free shifting. Not sure if you have ever noticed, but quite a few Honda linkages have little weights on them in some parts. I personally have a Skunk2 short shifter and have had no problems. Good luck with this one though.
Old Jun 27, 2004 | 10:10 AM
thanks HondaFanatics
Old Jun 27, 2004 | 11:23 AM
slowest_ls_swap_ever's Avatar
I had a Hurst that hit my exhaust too, but only in 3rd. it was hitting the heat sheild, and I just bent it out of the way.
Old Jun 27, 2004 | 04:13 PM
well it hitting my exhaust real bad
Old Jun 27, 2004 | 04:17 PM
99blackcivicSi's Avatar
Get rid of that POS and buy a GSR shifter. Nuff said
Old Jun 27, 2004 | 05:40 PM
AlphaQup's Avatar
Default Re: (99blackcivicSi)
B&M doooooode
Old Jun 27, 2004 | 05:43 PM
Two_K Si's Avatar
Default Re: (AlphaQup)
Or just bend your exhaust hangers a bit to drop the pipe a little.
white_db8
Jun 28, 2007 02:53 PM
BILLisCHILL
Aug 16, 2006 06:05 AM
civickidd99
11
Oct 15, 2003 12:07 PM
same ol' civic
Oct 1, 2003 10:55 AM
