short shifter problem fix?
We put a no-name short shifter on my buddy's 99 coupe the other day and it rubs on the heat shield. I noticed that there is a rubber exhaust hanger about a foot back from where theshifter is rubbing. Now my question is, could you get one of those universal rubber hangers and use a different hole and drop the exhaust a little or would we have to drop it in the rear too? Thanks alot!
I want to be MADE into Ice-T
Re: short shifter problem fix? (mox99)
i had the same deal with mine, the bottom of the shifter was rubbing on my heat sheild, so i tried to re-install the shifter thinking it was put in wrong, but no it just did not fit right, so i ordered a new shifter (skunk2) because my no name broke on my with part of the shifter still in the ****, i aslo picked up some bushings from inlinefour.com ($18.oo shiped) and do not have the problem any more.
Re: (pdiggitydogg)
i tired to bend mine, but i just dealt with it for a while untill the shifter broke, and just 3 day's ago i got a new exhaust any way's, stright off the down pipe, all the way back untill the E.S Tuning muffler so no i did not bend anything but i don't have a heat shield now for it to rub on.
Re: (Evil_gambit33)
wouldn't removing the heat shield cause the shifter to get warm. Thanks for the replies, any idea on lowering the exhaust?
Re: (mox99)
i had the same problem but i know what the prob is,... you buy the short shifter and it says 88-00 civic correct? wrong, i believe its only up to 95 because the part in between the bushings and the ball is too long.. for ex. if you look at a neuspeed short shifter for a 96-00 civic its way short ill try to find a pic on here... and my short shifter from ebay is still laying around my garage
88-95
..i cant find the 96-00 one yet... still looking
Modified by shaun311 at 7:47 PM 10/14/2003
88-95
Re: (shaun311)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shaun311 »</TD></TR><TR><TD CLASS="quote">... i believe its only up to 95 because the part in between the bushings and the ball is too long.. for ex. if you look at a neuspeed short shifter for a 96-00 civic its way short... </TD></TR></TABLE>
The length between the ball and the bushings is what makes the throw short. If the piece between the ball and bushings was shorter then you would be back to a stock shifter. Bend your sheild.
Re: (realblag)
take off your b-pipe, and bend the hanger near the shifter up towards the bottom of the car, what this will do is let the b-pipe sit just a bit lower, allowing enough clearance for the shifter. I done this to mine and my friends car.
You can just take the stock shifter, and cut it. That would be a much cheaper solution if all you wanted is a shorter throw. All you would have to do is get an aftermarket shiftknob since there would be no more threads for the OEM one.
Re: (realblag)
"The length between the ball and the bushings is what makes the throw short. If the piece between the ball and bushings was shorter then you would be back to a stock shifter. Bend your sheild."
....someone correct me if im wrong but doesnt the length from the ball to the **** make it a shorter shift (mac trucks for ex.) not ness. the part between the ball the the bushings
Re: (shaun311)
yes, the distance between ball and bearings is what makes the throw shorter, basically it just changes the pivot point. Also, short shifters are like 3/4-1" shorter than OEM.
