What the heck is my car doing!
Old Nov 17, 2001 | 11:43 AM
ActiveAero's Avatar
Paragraph Alert
25 Year Member
Community Builder
Community Influencer
Default What the heck is my car doing!
Ok my car has been missing a little at high rpm's. I think it is because of the spark plugs I have, but who knows. Anyway I decided to rev my engine up slowly in nuetral to make sure everything was sounding nice and smooth. I revved her up to about 8k and held it there for a second. Suddenly the engine kind of cut and the rpms fell to about 7,500 before returning back to 8k. A few seconds later it did it again. I waited a minute before trying again and this time nothing happened as I held the revs at 8k for about 5-6seconds. The engine feels smooth as silk until it cuts out or misfires or whatever it's doing. It's almost like the fuel is getting cut for a brief second. What could the problem be? I'm going to the dealer soon but I want to have some idea. Is it the plugs, fuel system, ecu, distributor? Thanks in advance.
Old Nov 17, 2001 | 11:50 AM
Type Goch's Avatar
New User
Default Re: What the heck is my car doing! (ActiveAero)
it sounds like revlimiter but it shouldnt kick in at 8k unless it does that in neutral..
Old Nov 17, 2001 | 11:59 AM
Black SVT's Avatar
Default Re: What the heck is my car doing! (Type Goch)
Damn,Sounds like the Legendary super ITR is having problems.Your the expert here.Shouldn't you be telling us what is wrong with it?
Old Nov 17, 2001 | 12:11 PM
Dr Pooface's Avatar
Default Re: What the heck is my car doing! (Dc2k-specR)
What kind of gas are you useing?
Old Nov 17, 2001 | 12:46 PM
DannyITR's Avatar
Default Re: What the heck is my car doing! (Dr Pooface)
Exact same thing happend to me. You know what the problem was......I had NO oil in the car. Check the oil immediately.
Old Nov 17, 2001 | 01:09 PM
Jon7's Avatar
My guess is a bad fuel pump.
Old Nov 17, 2001 | 01:14 PM
B2FiNiTY's Avatar
I'm guessing oil pressure. Check your fuel pump when you start up your car.
Old Nov 17, 2001 | 03:53 PM
TypeRvtec18's Avatar
New User
Default Re: What the heck is my car doing! (B2FiNiTY)
would incorrectly gapping the spark plugs have anything to do with this?
Old Nov 17, 2001 | 06:33 PM
PiYoImuT's Avatar
Default Re: What the heck is my car doing! (TypeRvtec18)
somehow, I always thought that revving the engine to the rev limiter in neutral (without load) is bad..
oh well.. anyone can confirm this?
Old Nov 17, 2001 | 09:14 PM
B2FiNiTY's Avatar
Default Re: What the heck is my car doing! (PiYoImuT)
Yea it is bad. I forgot wether because you don't have a load on the engine or the transmission. Its one of those.
Old Nov 17, 2001 | 10:08 PM
lotus's Avatar
New User
Very very very bad... don't do that again... ever... with no load the motor is loose and sloppy at sustained rpms... any rpms.. the problem is magnified by higher rpms as the stresses on the motor increase expotentially (sp)
If you are having a need to do that drive the car or use a dyno... I've seen guy's with crank triggered ignitions ( not me of course ) get timing fluctuations from crank flex while holding high rpm in neutral, causing mis fire..
The result obviously will be a rod out the side of the block... or some such thing..
[Modified by lotus, 7:10 AM 11/18/2001]
AndreaMason
Oct 9, 2017 11:47 PM
89bluehatch
Feb 11, 2007 08:16 AM
wrXtian
Aug 6, 2005 04:05 PM
Hapa88
Apr 23, 2003 10:45 AM
buckfittyone
Jul 20, 2002 01:45 PM
