Front LCA bushing install help
Old Jun 24, 2004 | 04:30 PM
93civicsedan's Avatar
Default Front LCA bushing install help
I am in the process of installing the es master bushing set and I need some help. What technique have people used to get the bushing in the picture below out? Its one of the ones for the front lower control arm. I have a press but I cant figure out a way to press it out since the arm has a curve to it. Hope someone can help, thanks.
Old Jun 24, 2004 | 04:39 PM
moto27cm's Avatar
Default Re: Front LCA bushing install help (93civicsedan)
Unbolt the rearward arm from it. You wont have any clearance problems then.
Old Jun 24, 2004 | 04:42 PM
Default Re: Front LCA bushing install help (moto27cm)
I did that already but since the arm has a curve its difficult to position it on the press.
Old Jun 24, 2004 | 04:46 PM
moto27cm's Avatar
It should be cake. Have your buddy hold it while it rests on a big pipe or socket. Then press that dude out.
Old Jun 24, 2004 | 04:57 PM
Jaesung's Avatar
that bushing should be taken out by a mechanic. it's a toughy one
Old Jun 25, 2004 | 07:25 AM
ruthless013's Avatar
some napa stores have a press, should be less than $10.
Old Jun 25, 2004 | 09:01 AM
Jamez's Avatar
Burn, cut, hammer. For more info :
http://pages.infinit.net/sickware/polyinstall.html
Old Jun 25, 2004 | 09:06 AM
Hart-n-Sol's Avatar
i just used some shims to even the lca out. then pressed out the bushing. good luck.
Old Jun 25, 2004 | 09:07 AM
The Internet Tough Guy's Avatar
Default Re: Front LCA bushing install help (Jamez)
when i did that i put it in a big *** vice and used a ball joint press & impact gun.
it took some persuasion, but it came out in a few minutes.
i certainly don't envy you right now
Old Jun 25, 2004 | 09:13 AM
Animal's Avatar
Default Re: Front LCA bushing install help (jwn7)
We have always used sockets and the balljoint press kit. I normally just take my time and beat them out but it takes a lot of work and even more patience.
Old Jun 25, 2004 | 11:39 AM
teal_dx's Avatar
propane torch, and have some ventilation cause the burning rubber will leave a black soot on everything in your garage. (or maybe only if you use fire for every bushing) for the rears I just took the arm out and set it in some hot charcoals and came back in 5 mins... burnt clean out!
you'll love the ES master kit, makes a WORLD of difference!!
Old Jun 25, 2004 | 11:50 AM
Default Re: Front LCA bushing install help (teal_dx)
thanks for all your input. I managed to remove the bushing by pressing out the inner sleeve and then using a hacksaw to cut through the shell. Then I used a screwdriver and hammered it out. I am pissed now though cause when I opened up my kit and was going through the parts, it seems like I am missing some of the metal sleeves. Anyone know where I can get replacements?
Old Jun 25, 2004 | 11:51 AM
BeerMan's Avatar
Yup burn and chip the rubber out using a propane torch and screw driver . Then carefully cut the metal sleeve out using a hacksaw.
I just did these bushings last week using this method. It is not that difficult, just takes some patience.
nevermind, beat me to it.
oresama
Apr 15, 2012 07:54 PM
efyou999
Suspension & Brakes
10
May 28, 2010 09:12 AM
spatula
Dec 29, 2008 02:46 PM
rogue420
Jul 26, 2007 08:11 AM
Loserkidwac
Jul 5, 2006 11:57 AM
