Real quick! SOHC crank spec question!
Old Jun 24, 2004 | 04:15 PM
Em0ne's Avatar
Default Real quick! SOHC crank spec question!
Ok well my friend spun a bearing and fukd!!! the journal in his 97 civic ex. Now we are trying to find a crank. I threw all my old D16Z6 motors away and now we need a crank. We found a 89 1.6L (a D16A or something) and we need to know if the stroke of the crank and the overall specs on the crank are identical so we can get this turd running. Thanks!
Old Jun 24, 2004 | 04:22 PM
Em0ne's Avatar
Default Re: Real quick! SOHC crank spec question! (Em0ne)
bump!!!!!!!!!!!
Old Jun 28, 2004 | 07:51 PM
Ricky1213's Avatar
I'm curious as well if a z6 crank will go into a y8 block?
Old Sep 14, 2005 | 02:30 PM
DelSolDon's Avatar
Default Re: Real quick! SOHC crank spec question! (Ricky1213)
bumping from the dead cause i want to know too.
Old Sep 15, 2005 | 06:27 AM
DelSolDon's Avatar
Default Re: Real quick! SOHC crank spec question! (DelSolDon)
are A6, Z6, and Y8 cranks the same??
Old Sep 15, 2005 | 01:26 PM
Mista Bone's Avatar
D Tranny Guru
Honda list a different part number for the 96+ cranks, likely due to the crank angle sensor setup.....
Old Sep 15, 2005 | 01:28 PM
Mista Bone's Avatar
D Tranny Guru
Default Re: (Mista Bone)
Honda list a different part number for the 96+ cranks.........likely the snout changed when they changed the oil pump setup for the crank sensor.
Old Sep 15, 2005 | 05:52 PM
DelSolDon's Avatar
thanks bone, i shoulda just asked you
Old Sep 15, 2005 | 06:23 PM
Jim Truett's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mista Bone &raquo;</TD></TR><TR><TD CLASS="quote">Honda list a different part number for the 96+ cranks.........likely the snout changed when they changed the oil pump setup for the crank sensor.</TD></TR></TABLE>
Honda changed alot of part numbers for '96+. Just looking at them, the Y8 crank is the same physically. The crank pulley has the teeth for the CPS. The snout change came in '01, with the D17 cranks running the larger 28mm snout and pump drive like the B series. I know the DOHC ZC crank will work in an A6 and Z6, so I would assume the D16A1 crank will work too. The stroke is the same, so if the crank fits the journals it should work.
NowLoading94
Feb 4, 2014 11:23 AM
BEYAAAH
Jan 30, 2008 03:10 PM
viskii420
Jun 28, 2007 09:40 AM
jdmlife
Oct 20, 2004 09:07 PM
