Car wont start. Getting weird spark/ignition issues. PLEASE HELP
Old Jun 24, 2004 | 01:22 PM
Vtak's Avatar
Default Car wont start. Getting weird spark/ignition issues. PLEASE HELP
Alright heres the deal. I have an ls/vtec. just had it professionaly rebuilt. I installed it. Im getting fuel, fuel pressure, oil and oil pressure. But it wont start. Only cranks. I pulled the plugs, they are covered in fuel. I checked the spark. Its only getting spark on #1 and its a very erratic spark. It has a new coil,rotor,cap,plugs,and wires. All the 3 engine grounds are good. Is there a special procedure to reinstalling the dizzy on a new motor?(ie; alignment etc). I need to get this thing started soon. Also i have gotten a few nice backfires out of it. P28 w/ hondata S200. Any help is greatly appreciated.
Catch me on AIM if you want to @ Onthecam93. TIA
Old Jun 24, 2004 | 01:30 PM
Vtak's Avatar
Default Re: Car wont start. Getting weird spark/ignition issues. PLEASE HELP (ls_vtec_gs-r)
Bump it up...Anyone?
Old Jun 24, 2004 | 02:36 PM
backdraft's Avatar
It could be a faulty Igniter, It has happened to me before and it was the igniter..... Its like 60 bucks from the dealer. Also, check to make sure you put the distributer back in the slot the right way... It should only fit in smoothly one way... If it goes in both ways take the cap off and put the motor to TDC and check to see if the rotor is at #1 .... If it isn't, take your distributer off and replace it so that it is at #1... I hope this helps..
Old Jun 28, 2004 | 09:34 AM
Circuit Star-29's Avatar
Default Re: Car wont start. Getting weird spark/ignition issues. PLEASE HELP (backdraft)
Well, Who tuned your hondata? Check your perameters for the ignition tables.
Old Jun 30, 2004 | 02:54 PM
Default Re: Car wont start. Getting weird spark/ignition issues. PLEASE HELP (nathan atwell)
It could be your Coil too. check that.
redmon_e
Jan 5, 2015 11:47 AM
scotty.b16a1
Dec 31, 2012 01:54 PM
quad
20
Mar 14, 2007 05:16 AM
valerie34
Jun 30, 2005 07:42 AM
kell211
May 24, 2005 10:50 PM
