EK Power door conversion-WHOLE DOOR-(searched)
Hey guys,
sorry if this was already posted-searched couldn't find-
I am planning on converting the doors on my 98 hatch to power,
My door was hit so I am swapping the complete doors,
I will have both doors complete and the Floor harness,
anything else I need? Was there a write up on this?
any help would be appreciated-----
thanks guys
thanks guys
i'm actually in the process of doing right now, although i have absolutely no write-ups/documentation on it. Well not swapping the whole door, but adding the power door locks/windows. you need the door harnesses, switches, floor harness. should be good to go. Oh, and fuses/relays as necessary, although im not positive if they are already there. I think they are?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by C-West Civic »</TD></TR><TR><TD CLASS="quote">Lemme see if I can get my buddy to write something ( if he remembers - was awhile ago ). He did this swap in his hatch.</TD></TR></TABLE>
that would be great---
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HypeR0070 »</TD></TR><TR><TD CLASS="quote">i'm actually in the process of doing right now, although i have absolutely no write-ups/documentation on it. Well not swapping the whole door, but adding the power door locks/windows. you need the door harnesses, switches, floor harness. should be good to go. Oh, and fuses/relays as necessary, although im not positive if they are already there. I think they are?
Thanks, In my searches I pulled up MAD posts about the full conversion,
I am more concerned about whats involved in the hopefully simple conversipn of the complete doors,
also, does anyone know off hand if the Black SI doors and DX doors same color?
"hope so"
</TD></TR></TABLE>Thanks, In my searches I pulled up MAD posts about the full conversion,
"hope so"
i just wired ex doors on my dx and boy was it a pain in the ***. someone on this board did a faq write up on the whole thing, i ll have to search on it
i did end up buying the ex floor harness for $ 121 but ended up not using it because i did not want to replace the whole thing (goes all the way back to the fuel pump) i ended up just making my own wiring.
But anyways use a multi-meter and a helms.
good luck
good luck
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 12 oz. »</TD></TR><TR><TD CLASS="quote">i just wired ex doors on my dx and boy was it a pain in the ***. someone on this board did a faq write up on the whole thing, i ll have to search on it
good luck</TD></TR></TABLE>
I was thinkin bout wiring in the power windows, but people have told me I'm better off with the whole floor harness--I'm not overly concerned with replacing it(car is gutted) fuel pump very accesible... I was more concerned with whether I have everything I need.............I HATE SUPRISES!!!!!
thanks...
thanks...
if you have the door harness then it should plug right in, most honda models are pre wired for power everything, you just need the harness that plugs into the door, plug it in under the fender to the conector, and your done. Thats all i had to do. hope that helps
what year ek is this anyhow?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jdm Ek Hatch »</TD></TR><TR><TD CLASS="quote">if you have the door harness then it should plug right in, most honda models are pre wired for power everything, you just need the harness that plugs into the door, plug it in under the fender to the conector, and your done. Thats all i had to do. hope that helps
what year ek is this anyhow?</TD></TR></TABLE>
I was hoping someone would give me this answer---Nice!!!
thanks
p.s. its a 98 hatch
thanks
p.s. its a 98 hatch
cant be much different than this: http://sencless.dyndns.org/powerwindows/
by best friend put that page together after trying really hard to find ANY info on it.
hope it helps
hope it helps
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H22EKHATCH »</TD></TR><TR><TD CLASS="quote">thanks,
damn so the floor harness is year specific,
anyone got an EX 96-98 floor harness for cheap, </TD></TR></TABLE>yeah what year window conversion do you have, my hatch is a 2000 and i have 00 si doors. You should be able to match them, the harness for the door that plugs in should come with the window regulatior plugs, tweeters, speakers, mirrors, and door locks. You can alter it to however you need for the regulator (i think the plugs could be diffrent)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gelstudios »</TD></TR><TR><TD CLASS="quote">he said he was able to convert a 99-00 harness to work with his 96 coupe, but i dont know what that entails.</TD></TR></TABLE>
problly just cutting the plug that goes to the fuse box and splicing on the correct year/spec. plug------still rather get the 96-98ex harness
plug and play
all your guys help is apprciated
plug and play
"hope so" </TD></TR></TABLE>
They arent the exact same color, but you wont really be able to notice a ton of difference, on my 99 black SI i had, i swapped the trunk out for a couple days with a friend with a 99 ex (so i didnt have spoiler, and no holes in trunk), and the trunk color didnt match exact, but really couldnt tell unless u were looking for it, but then again on a 97 dx hatch a friend has, has a 99 SI front end, black again, and its a lil more obvious, but again nothing too too major, most people prolly wont notice unless you tell them
gl with the power windows
da9kid11
Oct 6, 2008 06:39 PM
lazii_boi08
14
Aug 22, 2007 02:14 PM
ekx4
Feb 2, 2004 07:21 AM
