High compression D16Y8 Pistons
Old Jun 24, 2004 | 01:14 AM
longjago's Avatar
Default High compression D16Y8 Pistons
I currently own a Civic EX 96 w/ AT(I know, its slow, but I drive whack when i have little sleep). I saw 11.5 compression ratio pistons for the D16Y8 from http://www.ariaspistons.com. Does anyone have any knowledge or experience on what these can do on a D16Y8 AT/MT? Also, if I change the rings, do I need an overbore set of rings if the cylinder walls haven't been overbored? Mileage is at 136K miles.
Old Jun 24, 2004 | 04:18 AM
sohc_boy's Avatar
Default Re: High compression D16Y8 Pistons (longjago)
do a search for spade's big post on d-series upgrades lots of good info there. i'm sure someone will chime in and post a link to it. you don't need oversized rings unless you bore the block and go with a larger piston.
Old Jun 24, 2004 | 04:25 AM
sohc_boy's Avatar
Default Re: High compression D16Y8 Pistons (sohc_boy)
https://honda-tech.com/zerothread?id=335078 found it.
Unseen Racer
Oct 7, 2008 06:56 AM
mushu315
Oct 30, 2004 08:35 PM
CRX_Control
Oct 20, 2004 02:58 PM
wrXtian
10
Dec 22, 2003 09:16 PM
