piston question
piston question
whats better
SRP D16Y8 : 75mm - 9.1:1 compression
SRP D16Y8 : 75.25mm - 9.1:1 compression
SRP D16Y8 : 75.5mm - 9.1:1 compression
SRP D16Y8 : 75mm - 10.5:1 compression
OR
SRP D16Y8 : 75.5mm - 10.5:1 compression
OR
Re: piston question (00b20vtecoupe)
The first 3 you listed are identical except for the bore size. If your cylinder walls are damaged, you would need a bore along with a hone. If not, the 75mm would be ideal. The other 2 are just stupid, for forced induction OR all motor. 10.5:1 is weaksauce.
