Axle replacement on a B16B
Old Jun 24, 2004 | 12:50 AM
Ricochet.'s Avatar
Default Axle replacement on a B16B
Both boots are torn wide open and have been for a few months. There's no knocking or anything (yet), but I want to replace them with strengthened half-shafts just in case. Will b16a2 shafts fit since I have an lsd?
Old Jun 24, 2004 | 01:03 AM
Junkiii Ek's Avatar
Default Re: Axle replacement on a B16B (Ricochet.)
all b-series are the same....but i can be wrong....
Old Jun 24, 2004 | 04:03 AM
integra6650's Avatar
go to napa remanufactured shaft are 70 bucks a pop
Old Jun 24, 2004 | 12:22 PM
Junkiii Ek's Avatar
Default Re: Axle replacement on a B16B (integra6650)
yup...
Old Jun 24, 2004 | 12:46 PM
japspec's Avatar
I just replaced my passenger side with a gsr axle non abs. The b16 axle should hold up fine.
Old Jun 24, 2004 | 12:48 PM
zer0.'s Avatar
Default Re: Axle replacement on a B16B (japspec)
any 94-01 b series axles will work...they are usually $100-$110 for 2. (with a core )
Old Jun 24, 2004 | 01:35 PM
OBD1Kenobe's Avatar
I believe there are some ITR axles w/ 36mm hub nuts. You don't want those.
All other 94+ B axles accept 32mm hub nuts and will work for you.
GL
Old Jun 26, 2004 | 10:41 PM
Junkiii Ek's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by japspec &raquo;</TD></TR><TR><TD CLASS="quote">I just replaced my passenger side with a gsr axle non abs. The b16 axle should hold up fine.</TD></TR></TABLE>
sounds good
RaCk
Sep 1, 2006 05:03 AM
nonvteclude
Aug 7, 2006 08:45 PM
1994CivicGS-R
Jan 15, 2006 11:00 AM
NstyGrnHatch
10
Feb 15, 2005 11:35 AM
d15b7racer
Dec 8, 2004 06:29 PM
