Axle replacement on a B16B
Both boots are torn wide open and have been for a few months. There's no knocking or anything (yet), but I want to replace them with strengthened half-shafts just in case. Will b16a2 shafts fit since I have an lsd?
Re: Axle replacement on a B16B (Ricochet.)
I believe there are some ITR axles w/ 36mm hub nuts. You don't want those.
All other 94+ B axles accept 32mm hub nuts and will work for you.
GL
GL
Re: Axle replacement on a B16B (japspec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by japspec »</TD></TR><TR><TD CLASS="quote">I just replaced my passenger side with a gsr axle non abs. The b16 axle should hold up fine.</TD></TR></TABLE>
sounds good
sounds good
NstyGrnHatch
10
02-15-2005 11:35 AM
