civic h22 ecu problem
Old Jun 24, 2004 | 12:03 AM
Blanket Jackson's Avatar
Default civic h22 ecu problem
k i have a 97 civic with an h22 and throwing check engine code 24 and it has no power tell vtec hits and it back fires. i just got the engine complete change over from hmotorsonline what did thng is my problem. do you think it could be my obd2 to obd1 converter.
Old Jun 24, 2004 | 06:03 AM
Jason kiDD's Avatar
Default Re: civic h22 ecu problem (HONDAofPOKY)
What year is the motor/ECU and do you get any other CELS?
Old Jun 24, 2004 | 11:54 PM
92-95 prelude and i not getting any other cels right now
Old Jun 25, 2004 | 12:22 AM
hondaZvic's Avatar
Default Re: (HONDAofPOKY)
where did u get ur conversion harness from? what company made it?
Old Jun 25, 2004 | 11:27 AM
Adam.'s Avatar
Default Re: (hondaZvic)
Check your wiring and make sure it's not grounding out anywhere.
Old Jun 26, 2004 | 11:49 PM
i think it is a hasport wiring converter and i had ProSpeedPower do the engine harness wiring. Should I try a new ecu. Is it a p13 ECU?
Modified by HONDAofPOKY at 11:24 PM 6/30/2004
Old Jul 2, 2004 | 08:07 PM
integr8er's Avatar
make sure ur dizzy isnt wired 180 degrees out
Old Jul 3, 2004 | 04:41 PM
hondaZvic's Avatar
Default Re: civic h22 ecu problem (integr8er)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integr8er &raquo;</TD></TR><TR><TD CLASS="quote">make sure ur dizzy isnt wired 180 degrees out</TD></TR></TABLE>
i did that when i first got my car going... didnt realize what had happend... and then we tuned it best we could.. months and months later.. figured it out, corrected it. and have been trying to tune ever since... eh...
Old Jul 4, 2004 | 02:40 PM
my dizzy 180 degrees out what is that. sorry but i dont know what you are talking about
Old Jul 4, 2004 | 05:10 PM
Honda_Tengoku's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HONDAofPOKY &raquo;</TD></TR><TR><TD CLASS="quote">my dizzy 180 degrees out what is that. sorry but i dont know what you are talking about</TD></TR></TABLE>
distributor. If its wired 180 degrees out it will still run, (like crap).
Old Jul 29, 2004 | 08:33 PM
lcaruca97's Avatar
Default Re: (Honda_Tengoku)
please explain a little better. I am having similar problems but i cant pinpoint it.
Old Jul 30, 2004 | 05:39 AM
uncle's Avatar
If you are not knowledgeable enough to fix this problem yourself, take it back in to whomever installed it and tell them it is not performing the way it should and that they need to fix it.
wally620
Jan 29, 2008 01:38 PM
omega_s14
Oct 31, 2005 04:45 PM
Ministry
Dec 6, 2002 07:57 AM
90H22
Aug 21, 2002 12:33 PM
