Removing motor soon, got a question
Old Jun 23, 2004 | 04:16 PM
RTW DC2R's Avatar
Default Removing motor soon, got a question
I think you are supposed to remove the motor with the head still attached, but can you safely remove it without the head? Are there any lift points on the block to safely hoist the motor out?
Old Jun 23, 2004 | 04:49 PM
seek167's Avatar
Default Re: Removing motor soon, got a question (RTW DC2)
i take the motor right out of the bottom , i set on a 4 way dolly and the lift the car up . go to uhaul and rent one for like 10 bucks
Old Jun 23, 2004 | 04:56 PM
v-attack's Avatar
From: First in Flight, Type Rs of East Coast, NC, FL
I highly recommend ^ after my first engine removal from a dc2. Every time after that I have dropped it from the bottom, and pulled it out on some sort of rollable skid/dolly
Makes removing it and installing it with the transmission still intact much easier.
Old Jun 23, 2004 | 05:29 PM
RTW DC2R's Avatar
I cant get the car high enough to do that. Im working on Jackstands and Im not gonna tow the car to a shop that has a lift.
Old Jun 23, 2004 | 05:32 PM
Evs-One's Avatar
Solbros Owns Me
Default Re: (RTW DC2)
you can use the alternator mount bracket and the front torque mount bracket for the block, and then wherever you decide on the tranny.
Is the head already off?? If not, just pull it all at once.
Old Jun 23, 2004 | 05:40 PM
RTW DC2R's Avatar
thanks
just took the head off 5min ago, will post pics in my other thread.
Old Jun 24, 2004 | 01:30 AM
seek167's Avatar
i use jack stands u just need a couple 2by 4 also
Old Jun 24, 2004 | 06:01 AM
Kendall's Avatar
There's nothing wrong with pulling it from the top, there are several appropriate mounting points, I usually back out one of the tranny bolts for one end, and then attach the other to the intake manifold. I do, however, prefer to remove the engine from the bottom. If you have access to a forklift, your life will be much easier as you can lift a pallet all the way to the oil pan.
MiraiZ
Feb 7, 2009 02:03 AM
spintboy
10
Mar 20, 2008 12:03 PM
Smith bPr
Honda S2000
32
Aug 14, 2007 12:37 PM
Stephdavis18
May 14, 2006 01:49 PM
metal-x
Oct 22, 2002 10:48 AM
