Pinging on VTEC
Old Jun 23, 2004 | 05:36 AM
tianporn's Avatar
Default Pinging on VTEC
Okay my B16a pings when i hit VTEC. I can audibly hear it since when VTEC kicks in i can hear it. Now as far as im aware the stock computer dumps a lot of fuel in when VTEC engages. Now why would it ping?
My engine has a ported and polished head. ECU has VAFC but settings has been initialised. Would you need to up the fuel if you have a ported and polished head?
Cheers
Old Jun 23, 2004 | 05:55 AM
Mike_C's Avatar
What octane are you running? It's a pretty high compression engine, you need a high octane.
Old Jun 23, 2004 | 06:09 AM
Deemeetree's Avatar
Electrician
On B-series VTEC motors you should run 92 octane, everyone I know runs 92 octane and never pings. How's you timing/ignition wires/spark plugs?
Old Jun 23, 2004 | 03:00 PM
tianporn's Avatar
Default Re: (Dimi)
Im running 96 or 98 octane because we can get that in New Zealand . I think its time to change wires and plugs. But i thought that wouldn't affect it since a weak spark would just lead to unburnt fuel? And I thought the ECU retards timing if its too advanced?
Old Jun 23, 2004 | 03:03 PM
Deemeetree's Avatar
Electrician
Default Re: (tianporn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tianporn &raquo;</TD></TR><TR><TD CLASS="quote">Im running 96 or 98 octane because we can get that in New Zealand . I think its time to change wires and plugs. But i thought that wouldn't affect it since a weak spark would just lead to unburnt fuel? And I thought the ECU retards timing if its too advanced?</TD></TR></TABLE>
Do Honda ECUs do this? The last time I heard they don't. I was surprised to hear this since my 1997 Jeep does. You can't advance or retard the timimg on that one, self adjusted by the ECU.
Old Jun 23, 2004 | 04:40 PM
Jimmy's Avatar
Global Moderator
Sounds like detonation..
Has anyone touched/messed with your timing any recently?
I would reccomend the highest octane you can run at the gas station.
goodluck
Old Jun 23, 2004 | 04:50 PM
TorganFM.'s Avatar
Default Re: (Jimmy)
Many countries measure octane a different way than the US. I think I've read that they measure different strings of hydrocarbons in other countries. I'm sure a Google search would clear things up.
Old Jun 23, 2004 | 05:13 PM
ScoobCivic's Avatar
Default Re: (Dimi)
is it okay to run 87?......mine never pings
Old Jun 23, 2004 | 05:17 PM
mario82686's Avatar
From: Between San Diego and the OC, SOCAL, United States
Damn California, the highest you can is 91 octane while in Mexico you can get 93.
Old Jun 24, 2004 | 05:06 AM
tianporn's Avatar
Default Re: (mario82686)
Yeah Im sure the ported and polished head alone wouldnt cause the pinging. Im guessing its the timing. Would advancing timing too much cause low RPM misfire too? Im going to get my car tuned up. I've never set timing on a car.
mayfly
22
Dec 21, 2008 10:48 AM
spinksy
May 12, 2008 01:36 PM
zenon8890
Aug 18, 2007 11:32 AM
curtisb16
Jul 26, 2007 07:01 AM
mojo_2711
May 13, 2005 09:10 PM
