Need instructions on Blitz dual sbc****pics inside****
Old Jun 22, 2004 | 09:40 PM
tegedrex's Avatar
Default Need instructions on Blitz dual sbc****pics inside****
Now the black and red wire twisted together Im pretty sure are power and ground, the solenoid not sure what goes where, and on the back of the contoll unit there is a tiny vaccum line not sure were that goes. Thanks for any help
Old Jun 23, 2004 | 09:19 AM
tegedrex's Avatar
Default Re: Need instructions on Blitz dual sbc****pics inside**** (tegedrex)
someone show some love
Old Jun 23, 2004 | 02:09 PM
tegedrex's Avatar
ttt
Old Jun 23, 2004 | 07:48 PM
tegedrex's Avatar
bump
Old Jun 23, 2004 | 08:08 PM
JDMwhiteDC2's Avatar
would the vaccum line go into any other vaccum line on the car...just as long as it can read your boost...kinda like a boost gauge?...im just guessing on this tho
Old Jun 23, 2004 | 08:30 PM
tegedrex's Avatar
Default Re: Need instructions on Blitz dual sbc****pics inside**** (JDMwhiteDC2)
yeah I figured out that part goes to the manifold or vacuum source after the tb. The soleniod is what has got me puzzeled
Old Jun 23, 2004 | 09:29 PM
shermanyang's Avatar
i had the instructions...let me take a look....damn...i don't have the files no longer. if i remember correctly since i used to run that same ebc on my old setup, one of those on top goes to a nipple vacuum source that you create 6 inches or so from the tb(blitz recommends this), and the other single nipple goes to the fitting on top of the wg.
Old Jun 23, 2004 | 10:25 PM
tegedrex's Avatar
Default Re: Need instructions on Blitz dual sbc****pics inside**** (shermanyang)
what about the compressor housing vac. source, and on the back of the contr. unit theres a switch "wg" and "ac". Whats this about
Old Jul 1, 2004 | 10:36 AM
Relic1's Avatar
I hooked one up last night. the solenoid is hooked in between the wastegate and the compressor housing to regulate the wastegate.
Red = power
black = ground
the switch on the back I guessed is WasteGate / AC???
wish I could read Japanese.
Old Aug 15, 2004 | 11:34 PM
tegedrex's Avatar
Default Re: (Relic1)
I see 3 nipples though which goes where
Old Aug 16, 2004 | 04:45 AM
dalepatters's Avatar
one nipple is in one is out the other one is a bleeder port the section of the solenoid that has two ports the one to the front is the bleeder port it stays open
Old Aug 16, 2004 | 11:07 AM
tegedrex's Avatar
Default Re: (dalepatters)
which one is the in from the turbo and which one goes to the wg
slowhitEJ1
Sep 27, 2009 07:27 AM
sp00led
Aug 20, 2008 09:38 AM
TurboBumblBee
Jun 4, 2003 07:32 AM
AB16A2T
May 29, 2003 07:52 PM
