B18c1 into 00civic, wire harness questions
Old Jun 22, 2004 | 09:39 PM
JDM-FREAK's Avatar
Default B18c1 into 00civic, wire harness questions
well, i'm thinking about doing motor swap by myself, and i have few questions here hmotorsonline told me that everything woluld be basically drop-in except i gotta modify wire harnesses.. what exactly am i looking at here?... can someone explain more details?.. and are there any other things i should look at??..
people who have done gsr swap to civic (96-00) any advise?...
thanks in advance..
p.s. i did use search..... didn't find good sources..
Old Jun 23, 2004 | 02:52 AM
SYD's Avatar
SYD
From: Bluffton/Hilton Head,SC / Ft. Lauderdale, FL, usa
Default Re: B18c1 into 00civic, wire harness questions (JDM-FREAK)
u may have to extend the some of the existing sensors(MAP/IAT/TPS)..if they dont reach properly..if they are kinda tight extend them instead of having them hanging on for dear life....( this all depending on what model u have)(DX usually requires a little)EX should be fine..if it wasnt already vtec add ..vtec, vtec oil press...., knock (if EX already has a knock) and the IAB selonoid(if u are running the gsr intake mani) and if it is dx u are gonna have to REpin your IAT to a 2 wire (DX is 3 wire).......remember when i say "what model" your using i mean what model wiring harness...........hope that helps..
Old Jun 23, 2004 | 03:24 AM
JDM-FREAK's Avatar
Default Re: B18c1 into 00civic, wire harness questions (bruceleeroy)
good info!!! mine is EX 2000, so basically i shouldn't worry about too much problems then?..
is there anything else i should look for??...
BUMP before work!!
Old Jun 23, 2004 | 04:24 AM
SYD's Avatar
SYD
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM-FREAK &raquo;</TD></TR><TR><TD CLASS="quote">good info!!! mine is EX 2000, so basically i shouldn't worry about too much problems then?..
BUMP before work!!</TD></TR></TABLE>
your job should be alot easier then..good luck
Old Jun 23, 2004 | 06:14 AM
deSigi's Avatar
You may also need to extend the primary O2 sensor. I'm not sure though. I had to on mine, but I have a DX harness.
Good luck
orange94teg
Mar 25, 2008 08:52 AM
FullJDMEg
May 4, 2006 11:13 PM
streetracerof06
17
Nov 14, 2005 01:18 PM
SiR HatchAlot
Oct 10, 2003 12:22 PM
