Gauge cluster problem please help!!
Old Jun 22, 2004 | 07:23 PM
c_buz's Avatar
Default Gauge cluster problem please help!!
I recently swapped my stock cluster for a jdm Si. Everything works fine except for the "door open" indicator which is located under the tach, and also the "seatbelt light" and "low fuel" warning don't work. I am not 100% sure on the low fuel, but I would hate to run out of fuel because I wanted to test the light. Any input is greatly appreciated.
Old Jun 22, 2004 | 08:00 PM
c_buz's Avatar
Default Re: Gauge cluster problem please help!! (c_buz)
c'mon guys I need your help.
Old Jun 22, 2004 | 08:31 PM
INVALID's Avatar
From: Why so you can pretend like youre interested, FL/OK
Pretty messed up that I attempted to help you out, but to do so I had to look through your history of topics and watched list.
Make it easier for anyone attempting to help and list the information from which vehicle to which. Mentioning what the cluster is from helps as well. I have never heard of a JDM SI.
Old Jun 23, 2004 | 05:34 AM
c_buz's Avatar
Default Re: Gauge cluster problem please help!! (INVALID)
Sorry about that. My car is a 1994 CX hatch that came without a tach. I was told that the JDM cluster was from an SI. Anyways, The Jdm cluster has white face gauges and orange numbers. I have seen it in this website before but can't find any pics of it.
Old Jun 23, 2004 | 05:37 AM
INVALID's Avatar
The seatbelt light should be working, but the low fuel and the door indicators will not. the 1992-95 Honda Civics were not available with either option.
Old Jun 23, 2004 | 06:13 AM
Deemeetree's Avatar
Electrician
Indeed, 1st, check the bulbs. many times these clusters come with blown bulbs, that might be the case. BTW, if your 2-wire harness that connects to your seatbelt harness connected. I forgot mine disconnected and it didn't come on. Reconnected it, viola!
Old Jun 23, 2004 | 07:40 PM
c_buz's Avatar
Default Re: (Dimi)
The seatbelt light started to work today. I will check the seatbelt connector anyways. thanks all for your help
Old Jun 23, 2004 | 07:43 PM
CPCivic04's Avatar
Is that it?
SOLFOOD94
24
May 2, 2012 04:29 PM
knoxville
Jun 8, 2005 07:25 AM
BlueIntegraBoy
16
Dec 19, 2004 10:27 PM
naya1civic
Jun 13, 2004 03:59 PM
irtep
15
Dec 22, 2002 10:29 PM
